proper amount of lifter preload?
hey guys, i'm doing heads and cam on my 99 ls1 trans am and i'm trying to determine proper push rod length. i need to know what the proper amount or range of preload should be on the lifter after i've found zero lash. my length checker is at 7.310 at zero lash, i measured with calipers. any idea? i don't know at all. any help is greatly appreciated.
Couple of things to be aware of. First, if you are using the Comp adjustable pushrod, it measures by counting turns and figuring out the length. Bottom line is Comp is trying to give you "Gauge Length" which is how they (and Trend who makes the Comp pushrods) determine length. The length you measured is "Overall Length". There is nothing wrong with that but Overall Length is approximately 0.017" longer then Gauge Length of the same pushrod so be aware of that when you order off the shelf pushrods.
There is a GM Engineer on Corvette Forum who recommends 0.060"-0.100" as GM lifter preload.
Also, if you order Manton pushrods (which I would recommend) they use Overall Length (which you measured) to make the pushrods. Manton has an 11/32" OD pushrod which is a killer pushrod and it fits most heads without any machining. 3/8" OD pushrods do not fit all heads.
ok so my gauge length is 7.293 plus .080 preload to split the difference. i have comp 7.400 rods now, think they'll work? or should i go with 7.350? they'll be comp pushrods again, thats all i can get over the next 2 days and this needs to be done by monday night.
Patrick G recommended .080" to .100" preload in this thread.
Ok I was searching in the wrong place (yes please slap me)...
I found it the chart in this thread (see the post by Matt/TSP): https://ls1tech.com/forums/advanced-...-question.html
LS1Tech Premium Sponsor
I'd go with 7.375" based on your zero-lash measurement!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
