spun cam bearing sound like bad lifter?
Old 04-18-2010, 02:55 PM
m6camaro's Avatar
Default spun cam bearing sound like bad lifter?
Apparently my passenger valve cover gasket blew the other night causing a drop in oil pressure. I was not aware of it for a few 5k-6k pulls with probably only 25-35 psi of oil pressure. The sound I am getting out of the motor now is very similar to a lifter that will not bleed up. It almost certainly is coming from the top end. I have checked all the rockers/springs/pushrods and everything looks good. It is louder on the passenger side so I pulled the head and replaced all the lifters. The ticking sound is still there. My mechanic thinks it might be a bad cam bearing. Anyone have experience with what a spun cam bearing sounds like?
Old 04-18-2010, 05:32 PM
joecar's Avatar
Valve cover gasket will not drop oil pressure (but I am wondering how it "blew")...
If cam bearing walks then it causes an internal oil leak (this is where you may be losing oil pressure).
Old 04-18-2010, 06:59 PM
bww3588's Avatar
the only way you can blow a VC gasket is too much crankcase pressure, via a faulty PCV system.
Old 04-18-2010, 07:44 PM
m6camaro's Avatar
Ya, the hose coming off my passenger valve cover was torn probably causing the PCV system to not work properly. When I started to first hear the ticking, my oil pressure would not get above 25 psi. I pulled both valve covers then reinstalled and oil leak and oil pressure problem was gone. I get 40-50 psi at idle now. It sounds almost identical to when I had a bad lifter after a head swap a year ago. But this time it almost sounds louder on the passenger side.
Old 04-19-2010, 04:09 PM
dudeiwin86's Avatar
drain the oil and see if you got and gold sparklies.
Quick Reply: spun cam bearing sound like bad lifter?
