370 w/ LS3/L92 top end questions
i really hate to buy the heads and intake just to find out that i have to buy different pistons than what i already plan on and it being more expensive. because right now, if i buy the L92 heads, LS3 intake, sell my current ported LS1 heads, and buy a 90mm tb ill be sitting at the $$$ spent if i keep my current heads and buy a Fast intake and TB for my current setup. actually i may come out ahead money and performance wise.
L92 heads 550 shipped
LS3 intake about 3XX ish
90mm tb around 300
thats about 1150 in parts
then i sell my ported heads for around 400
then im right at 750 which is less than im finding FAST 90/90 setups for right now and ill be ahead in performance as well....
90mm tb around 300
They will bolt on, I have an LQ9 with L92s.
The LS1 piston notch is for a 2.00" valve. An L92 valve relief is cut for a larger 2.160" valve. Although some piston companies just starte cutting L92 reliefs into everything.
You wont get 12:1 most likely. Im running true flat tops without any reliefs and Im right around 10.5:1
Watch PTV clearance VERY closely.
they are Mahle pistons, i havent bought them yet, and i dont think Mahle makes a piston with an L92/LS3 notch yet....i do have a mill and fixture to flycut pistons, so that fixture will work to mill the notches out a little bit. if i can get Mahle pistons with the correct releif i would, i just hate to drop another 200+ dollars on diamond pistons just to have the bigger notch when i can mill this one out. unless Mahle makes the same piston with the right notches for the same price that im missing out on.
I have flat top mahle pistons,with valve reliefs in my .030 over 6.0 that were advertised as LS1 pistons. I have 823 cast L92 heads that have .025 thousands shaved and I am running GM MLS head gaskets for a 6.2. I used some clay and turned it over and I had no issues. I didn't measure, just wanted to make sure there was no contact. If you want I can dig through my receipts to get the mahle piston part number. My cam is a TSP 233/239 .595/.603
basically i need the CD of a piston for 6.125 rods. however, thoes pistons come with a .927 pin boss.
so i either need to get a custom piston with the .945 pin boss and 1.304 CD that puts me .005 in the hole which is better than .026 out of the hole...
unless i could get away with .026 out of the hole, then i could use a 4.030 piston for stock rods (if i can find one) or if Jon@HKE can dig one up, cause all im finding on Wiseco's website in a 4.030 bore is for a 6.125 rod....
You will also need to buy 8 offset intake rockers and LS3/L92 rocker stands. You can reuse the exhaust rockers. The LS3/L92 heads like a lot of timing. I started with 12:1 CR but could only run 24-25 degrees of timing. I dropped the CR to 11:3 and could run 29-30 degrees of timing and made more power. Don't trade off CR for timing.
There are MUCH better cams out there for these heads.
Just my $.02
Just my $.02
Just my $.02
Just my $.02
the problem with my build is, my deck height on the block is kinda funky. the only pistons i can run with stock rods require me to bush the rods. however, the pistons also leave me .005 IN the hole. and im having a hard time finding a head gasket other than .051 thick. and im going to have to wait and get the short block assembled, and check PTV before i can decide how much i can mill the heads. but i honestly dont think ill be seeing anything over 10:1 compression...which saddens me becaues i know i dont need 12:1 after talking to a few people, but i think there is more power in a little more compression than 10:1.
Just my $.02
Just my $.02
