Do PRC dual springs ever bind ?
Old 04-23-2010, 10:56 PM
Pro_built7's Avatar
Default Do PRC dual springs ever bind ?
Got my PRC duals in awhile ago, about to do my ms3 install this weekend...
Can't help but wonder- have any of you had binding problems with them? It seems like the 2 springs could possibly bind on one another. Or am I just over worrying?
Old 04-23-2010, 11:59 PM
LilJayV10's Avatar
Any spring can bind with too much lift. Where the springs installed at the correct install height? What is the lift on the cam? What's max lift on the springs?
Anything can break if setup wrong.
Old 04-24-2010, 01:06 AM
Pro_built7's Avatar
Like I said in the first post,
Ms3 cam... .609 lift. Not installed yet..
I was just making a general inquiry as to if anyone has had the small inner valve spring bind on the larger outer valvespring, in a dual spring setup.
Just curious.
Old 04-24-2010, 02:42 AM
LilJayV10's Avatar
Like I said.
If you have the right spring, setup correctly then it shouldn't bind.
You also didn't mention the lift in your first post or what PRC springs you had.
Old 04-24-2010, 03:20 AM
Paint_It_Black's Avatar
Just curious.
Never heard of that without the inner one breaking.
Old 04-24-2010, 03:48 AM
LilJayV10's Avatar
Wouldn't the inner and outer spring be designed for the same amount of lift? What's the point of an outer spring that's good till .650 and an inner spring that goes to .600?
I guess I don't understand the question.
Old 04-24-2010, 04:00 AM
Yes they are designed for the same lift. He wants to know if they have ever interfered or "gotten in the way" of each other.
Old 04-24-2010, 04:06 AM
flippincamaro's Avatar
Ive ran prc on several engines, Ranging from turbo 6.0s to .619 lift cams. No problems ever.
Old 04-24-2010, 04:16 AM
LilJayV10's Avatar
Did I read it wrong the first time or was the question rephrased?
Old 04-24-2010, 08:57 AM
Duffster's Avatar
If I'm not mistaken, they are coiled in opposite directions and therefore can not bind each other (UNLESS one breaks)...
Old 04-24-2010, 11:52 AM
Pro_built7's Avatar
Like I said.
dude yes i did... I said I had the MS3 (really popular cam figure'd ppl would know.. but irrelevant to the question anyway which was specifically about the springs)
I also said I had Prc Duals.. which was the title of the thread.
So yes.. I did say both of those things...
guess I should have said .650 lift duals??
Still, irrelevant though, because All i'm inquiring about is if people have ever had
PRC DUALS (brand specific) bind upon themselves.
Let me "rephrase it"..
Have the 2 springs ever bound on each other and caused issues ?
Pro_built7's Avatar
Yes. exactly.
Old 04-24-2010, 11:56 AM
Pro_built7's Avatar
Good to hear.
Old 04-24-2010, 11:57 AM
Pro_built7's Avatar
I honestly don't know how to rephrase it any easier.
2 springs in a dual spring right....
can the inner spring bind on the outer spring causing breakage...
I didn't rephrase anything
Old 04-24-2010, 04:59 PM
Squirts11's Avatar
Chill dude, you're question has been answered...
Old 04-24-2010, 05:09 PM
1BAD_LS1 Tunes's Avatar
Ive run the PRC duals on several setups without problems, 7000rpm on a cam with .629 lift to a 5.3 turbo setup pushing 20psi...
Old 04-24-2010, 06:22 PM
35th SS's Avatar
prc duals here on a trex 608/614 lift.no coil bind.
Old 04-24-2010, 09:40 PM
DaveX's Avatar
They are designed to work together. There should not be any problems with the springs interfering with each other.
Old 04-25-2010, 02:18 PM
Pro_built7's Avatar
Thanks guys !
Old 04-26-2010, 09:45 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Like they said, the springs wind in opposite directions and cannot bind on each other. It is a tight enough fit that sometimes they'll feel like they won't move in and out when pushing them by hand, but that's a much different force/pressure than when installed and running too. You should be good to go with the MS3, no worries!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
