Single Piston Ring???
Hey guys I was installing some new pistons and rings and broke a single top ring. Is there any place that will sell me just a single ring or a set for one piston or do I have to buy another whole set of 8?? I just really need the one.
Thanks
Thanks
I just got done doing rings in my car and broke a second ring, i contacted mahle with no respose so i just ended up ordering a new set... I looked everywhere for even and set for a single piston and couldnt come up with anything.
Federal Mogul/Sealed Power/ Speed Pro sells 'open stock' rings by individual part number if that happens to be the set you used.
You may need to get online and call their tech hotline, I have ordered singles before.
Summit can probably do the order if you can provide them with the part number.
thanks for all the help guys, I actually got ahold of Federal Mogul and they gave me the part number for a single piston set (just put a "w" in front of the part# for the set of 8 lol) and called up Scoggin Dickey who had Federal Mogul drop ship it for me. Was like 22 bucks.
Iam using a crappy ring compressor which I blame for breaking that ring lol
^^^you are using a ring compressor for installing the rings on the piston ?
usually it is just used when you install the piston and the rod already assembled with the rings in to the bore
