All engine builders Read PLEASE!
is there anything wrong with this setup?
-Aluminum LS1, 4.030" Bore = 370 Cubes. resleeved with Melling cyclinder Sleeves
-LS1 3.622" Crank- stock
-Scat H-Beam Rods with ARP rod bolts- #2-350-5700-2000- RPM Machine
-Mahle Forged Pistons 4.030" Bore, Plasma Top Ring -4 valve relief -#LS1314030F04- Lingerfelter
-Comp Cam Custom Gind- Dur. 238/254- Lift .605/.612 Lobe 112LSA 112ICL
-Comp Pro Magnum Lifters- #875-16
-Stock Lifter Trays.
-Engine Balanced
-Clevite H Series "race bearings"
-Rollmaster double Timing Chain #1140
-LS6 Oil pump
Block has been Decked .015" for added compression.
With Stock GM gaskets .051" here is the following compression guide.
On 72cc Chamber heads (L92, LS3 heads) = 11.28 compression
On 67cc Chamber Heads (Stock 241, 853 Heads) = 12.03 compression Recommend E85 or race fuel
On 59cc Chamber Heads (5.3 or other Milled heads) = 13.49 compression Race fuel or E85 required for this compression
-Engine Balanced
-LS6 Oil pump
the PN you have listed for the rods, is for a small block chevy....not an LS1
also, the pistons are for stock length rods....
and with your deck height, a 6.098 rod and a 1.340 piston height, your piston will be .024 above the deck...that only leaves you with .027 quench. you need between .030 and .040
ii
-Engine Balanced
-LS6 Oil pump
-Engine Balanced
-LS6 Oil pump
the ls1 is a small block 350 playa
ii
ii
http://www.rpmmachine.com/scat-conne...am-chevy.shtml
Yes it is a chevy small block. No it's not a gen 1 small block or compatable with gen 1 parts. Check the specs they list those rods won't work.
That cam seems off the wall, doesn't look like you will be making enough power to justify sleeves, just buy a LS2 or Iron 6.0 block.
also I am confused, do you already have the sleeved block? or are you going to sleeve a block you have? is your block already decked? People don't usually deck the LS because the pistons already come out of the hole.
https://ls1tech.com/forums/parts-cla...led-ready.html
