How to properly install the cam/crank sensors
I had my motor out and I swapped the sensors to my new motor. I lined up the crank and cam sprockets dot to dot and then slid the sensors in. Was that the correct way? I think it is but, I want to be sure.
Is there anything else I should do related to the sensors before I fire it up?
I'll double check the manuals tonight to make sure if nobody else chimes in. I honestly didn't even check them when we put the motor in...just bolted it on and installed the motor. Coulda just lucked out when it fired right up
Originally Posted by Jason99T/A
Just bolt in and go. If you are using a new crank, PCM, or crank position sensor, you will have to perform a Crank Position relearn with a Tech2.
Why would a new crank require the relearn? Why would a new sensor require that too? I've never fully understood when the tech2 proceedure is actually needed, and when it isnt.
BTW, Doesn't EFILive Pro let you do that relearn now?
I can shift faster than you.
I have only had to do the Crank Position relearn one time on a car. This was when a new motor and PCM were installed in a customer's car.
According to GM, a relearn is needed whenever the following conditions are met:
- engine replacement
- PCM replacement
- anytime the crank pos. sensor to reluctor wheel gap is changed (new crankshaft, sensor,etc)
- if the battery is disconnected when the ignition is still on the ON position
The PCM uses the crank pos. sensor to keep the injector and ignition systems in syncronization, and to detect misfires. As the crankshaft is rotated, the reluctor wheel teeth interupt a magnetic field coming from the sensor. The PCM times the interval between these "pulses" and compares each new interval with the previous one. This is how the PCM finds out if an excessive change in crankshaft speed has occured. When the change is large enough, a misfire is considered detected.
And yes, EFI Live Pro can do the relearn as far as I know.
Jason
- PCM replacement
Jason
