What's the difference in porting and milling heads?
Old 06-03-2010, 08:22 AM
Blue_GTO1199's Avatar
Default What's the difference in porting and milling heads?
I found a set of milled 243's on craigslist for $300. I'm interested, but what exactly IS milling? Is it better than porting?
Old 06-03-2010, 08:30 AM
ttranssam's Avatar
Milling is shaving the whole bottom where the head meets the deck of the block. It lowers the compression adding a lol power. Porting heads is the inside runners and chambers getting cleaned and smoothend for better air flow
Old 06-03-2010, 08:34 AM
so if heads are milled, will they fit right on to my block, or do i need to do something else?
Also, is milling better than porting then?
Old 06-03-2010, 08:40 AM
smg267's Avatar
I would be careful and ask what they are milled to. You could run into PTV problems.
Old 06-03-2010, 08:41 AM
ttranssam's Avatar
milling will yeild some hp but porting i think will get you more. and yes they will fit fine...milling trues the surface area too.
Old 06-03-2010, 08:42 AM
ttranssam's Avatar
oh yea^^^ if you go with any aftermarket cam you have to watch your PTV pistion to valve clearance due to the heads being milled.
Old 06-03-2010, 08:43 AM
That's what i'm worried about...
Old 06-03-2010, 08:45 AM
ok, it says they were milled to 59cc
i'll have a comp 228/230 .571/.573 112lsa cam in there.
will that work?
Old 06-03-2010, 08:46 AM
snake95's Avatar
I'm sure it was just a typo, but milling raises your compression.
Old 06-03-2010, 08:48 AM
ttranssam's Avatar
your going to need to get them checked...you can do a play-doh job on it...put the heads on with two small strips of play-doh over the piston where the valves would hit and turn the motor over...thats the gettho way...
Old 06-03-2010, 08:50 AM
ttranssam's Avatar
^^^woops my bad. im buildin a turbo car so the last few weeks for me everything is about lowering my compression...lol sorry
Old 06-03-2010, 08:52 AM
there's also a guy selling ported and milled 853's for the same price.
he says they were milled .015 and ported to add 50cfm as proven on the superflow 600 flow bench
Old 06-03-2010, 08:55 AM
ttranssam's Avatar
853s are kind of junk...there the second worse head you can get. id shoot for some 243s or 799s them in stock form are way better then 806-853-241s...
Quick Reply: What's the difference in porting and milling heads?
