918 valve springs, ms3 cam??
Old 06-08-2010, 05:31 PM
SSponyh8R's Avatar
Default 918 valve springs, ms3 cam??
i got a set of 918 valve spring the paper that came with them said 625 lift will they hold iv heard alot of bad things bot these spring after 600 lift and i was gona run a torqer 2 cam but realy wana run ms3. wat do u guys think??
Old 06-08-2010, 05:34 PM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
I'd recommend either the PAC 1518's (.650" lift) or the PRC dual spring kit for the MS3. While some do push the 918's past .600" lift, we do not recommend it. You get a much longer life out of the duals along with the added assurance that if you ever did break a spring that wouldn't be having to replace a short-block!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 06-08-2010, 05:44 PM
SSponyh8R's Avatar
how long does a set of dauls last,
Old 06-08-2010, 07:32 PM
00cls1camaross's Avatar
Yeah, the EHT vs the normal PRC duals
Old 06-08-2010, 10:57 PM
SSponyh8R's Avatar
i mite use the torquer 2 cam wat guys think?
Old 06-08-2010, 11:14 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Either way I would run a spring that will support whatever cam you choose.
Old 06-09-2010, 02:01 PM
SSponyh8R's Avatar
have a ls6 hott cam sitin around i mite use 525/525 lift 218/228 dur
Old 06-09-2010, 02:22 PM
01ssreda4's Avatar
Most important thing is the springs are set-up correctly.
Old 06-09-2010, 05:11 PM
SSponyh8R's Avatar
i daily drive my car and i have a 3800 stall and 373s and i want a good cam wat u guys think? but will work with my springs
Old 06-09-2010, 08:21 PM
SweetS10V8's Avatar
I agree. The springs and a good overall valvetrain.
I run 918s on on my .621 lift cam with out issue, and I still had to shim them .030" ish to get them all where I wanted them.
Old 06-09-2010, 11:28 PM
Quik Sand's Avatar
I run the newer 918's with my torquer 2. The v2 is a cam with a lift just short of .600 so I went with it. With an MS3 I would run something else...
Old 06-09-2010, 11:53 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Comp has them rated lower on purpose. Its really no surprise they can handle over .600
Old 06-10-2010, 02:23 AM
Paint_It_Black's Avatar
Kinda the same deal with the PAC 1218's vs the 1518's. The 1218's are really no different than the 1518's, but they don't go through all the processes the 1518's do, and thus get a lower rating for durability issues.
Old 06-10-2010, 02:54 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Exactly. It keeps the people that run a .601 lift cam installed at a Nissan dealearship from coming back and blaming them.
Quick Reply: 918 valve springs, ms3 cam??
