Estimate my HP too (please)
Everyone else is doing it! But I'd like ET estimates too
LQ4, stock bottom end
Stock 243 Heads (10.4:1 compression)
Lunati 2200 - 6800 CAMSHAFT, GM LS VHRX278-12X 278/282 adv. 227/231 @.050 .651/.651 112/108 LSA/ICL
Stock truck intake
T56 w/4.56 gears and 26" hoosier slicks -- 4000LB truck (race ready w/driver)
1 3/4 headers, 3" duals with x-pipe.
Stock truck intake
Stock truck intake
Stock truck intake
I would say you might see 435 at the wheels.
Gotcha; I'm not familiar with chassis dyno theory -- I hope to have it together by August/September, so I will revive this thread with the track results, good or bad. Previous best was 14.2 @ 98 with 400 FWHP 350 3.73's and a 4 speed manual (same 1st gear as a T56). 60' times were in the 2.0 range, but gearing was not on my side. I think I can cut several tenths off the 60' with the 4.56's.
This is incorrect. The standard 1999-2007 truck intakes are terrible, the Trailblazer SS style(on 2007+trucks also) truck intake is better though.
I just saw a dyno test that showed that the FAST 102mm LSXRT truck intake made 20rwhp over the Trailblazer SS intake on the truck forum the other day.
i feel the 1 3/4 headers will help move that heavy truck off the line compared to the big ones. the large lift/short duration figure should promote high volume in each primary so i see where your coming from, but the split will help to offset that.
