Which cam please need opinions
hellooo
i have two cams to choose from
and which one will give more power ??
the car is LS2 A4 and its my DD
1:: 222/226 - 581/609 - 117lsa
2:: 224/224 - 581/581 - 115lsa
thank you
thank you
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Whose lobes are these ground on? I dont recognize them. Plus they have some near stock LSA's so I figured they are probably pretty sleeper sounding. Check this thread out: https://ls1tech.com/forums/dynamomet...k-results.html
they are customed cams a friend of mine have them new in the box
i know that both will sound stock, but which one will have more power ?
or whats the power range of them ?
thank you
thank you
but im more into the 224
thanks
well entry level xer lobes have around .581 lift but that 226 lobe looks odd could be xfi but i would have to check. I lean toward the 224 as well it will just be a bit more sneaky then a 114lsa and have a bit wider band. I shoud make good power. the other cam should still gain a few and looks like a decent fi cam easy to tune.
