went to the track and now this
well i took my first pass hit 2nd dash lights went outand came back oni though we its still runniing good . 2nd pass it kinda died on launch and half way down the track it started popping i let out and know i tried to drive it home and my oil pressure is at 20 and the service vehical and majority of the lights came on i cannot drive it over 55 or 1800 rpm with the car stopping and trying to die with loud back fires sound like a really bad missfire the car is camed with all the supporting mods built by xxx motorsports this is also the first time to the track since work was finished
well pulled off the valve cover thier was a ground wire that went to the pcm pinched in the valve cover and was barely hanging on gonna reconnected it see what happens
Your posts barely make sense. Its all one sentence. Use this next time www.hookedonphonics.com
Might want to check your starter wires. Sounds like something is shorting out. How the hell do you get the ground strap under the valve cover thats just retarded.. If a main power power wire is shorting against some thing metalit will bang out and miss just like your discribeing and cause your guages to go hay wire because they are also electronic.
i am with this guy!!!! its a start
I Thought about taking it back to xxx, but im military and i got moved to NC and they are in FL, checked the starter wires and everything was tight . I never thought after all the work the engine would **** on me. I new i should have saved the 2700.00 and did it my self!
http://s244.photobucket.com/albums/g...t=M4H00810.mp4 video clip! I dont believe the chirp sound is comeing from the belts it sounds more internal
