Change Camshaft without Removing the Pulley? possible?
Old 07-20-2010, 10:05 AM
Fastdriver1992's Avatar
Default Change Camshaft without Removing the Pulley? possible?
is it possible to remove the camshaft without taking off the crank pulley?
i wanted to try and lower the oil pan in the front and take 1 or 2 belt tensioners off and ROTATE the timing chain cover about 90 degrees on the crank just enough to get the camshaft out. i may not have access to a pulley puller which is what made me think of this
has anyone done this?? do u think it would work?
Thanks
Anthony
Old 07-20-2010, 10:06 AM
_GTO_'s Avatar
No way !!!
Old 07-20-2010, 10:19 AM
TooLateVTEC's Avatar
Dont think its gonna work.
You can rent a pulley puller/installer at parts stores like Advance and Auto Zone. You have to pay full price for whatever tool your borrowing up front (in case you dont bring it back) and you get your money back when you return it.
Old 07-20-2010, 10:32 AM
TopFlite's Avatar
It more than likely will not work. When you get your camshaft, if you have not already, opt for the Edelbrock 2 piece timing cover should you want to change your cam again in the future without removing the crank pulley.
Old 07-20-2010, 10:49 AM
garygnu's Avatar
buy a puller if that don't work.
Old 07-20-2010, 12:49 PM
Yahelou's Avatar
yea thats not gonna work. i have the tool to reinstall the pulley without stripping the threads. pm me if ur interested.
Old 07-20-2010, 02:27 PM
NVR_SPDS's Avatar
Dont think it will work, unless you have a two piece timing cover on there already.. its the only way i can think of.
If its the stock balancer, just rent a 3 jaw puller, and pop it off. Then get some all-thread to re-install it.
Old 07-20-2010, 03:26 PM
DVS99TRANS's Avatar
+1 to all the above. The snout of the crank pully sits in the timing cover and it has to come off for sure. Sorry fella.
And in order to get the clearance to twist the timing cover with the oil pan shifted, the engine will have to come off a motor mount and tilted to make room for that. My vote, just pull the pulley. If you don't have one, get a 25% or 10% underdrive pulley while your at it.
Old 07-20-2010, 03:56 PM
Longshot LCMS's Avatar
It's not hard to remove the crank pulley, nor reinstall it. Took me and a buddy 10 minutes combined. You're not saving any time or real effort. Do it once, do it right.
Old 07-20-2010, 05:09 PM
The_Rizzle's Avatar
The problem isn't even room on the outside of the cover, its inside - the cover hits the oil pump very early in the rotation is both directions. I've tried it. Don't forget to replace the balancer bolt too. ARP makes a nice re-usable one if you plan on pulling the cover ever again.
Old 07-20-2010, 06:56 PM
thnks guys i just thought of the oil pump problem tday. i thought that the puller was ls1 specific thats y i thought id try not to remove it.
thnks
Anthony
