What's it take to make 360-365rwhp?
Old 07-26-2010, 02:53 PM
docwyte's Avatar
Default What's it take to make 360-365rwhp?
Can't go over 371 rwhp without breaking out of my class for time trials. I want to give myself a little room for dyno error, so I'm shooting for 360rwhp.
Stock everything on the motor now, would prefer to do simple bolt ons to get there.
What will it take?
TIA!
Old 07-26-2010, 03:25 PM
Taspeed's Avatar
lid, exhaust, headers, and a decent intake...if you don't mind getting in to the engine you could stick a cam in. You could probably stick in a 224 cam only with all stock everything else and be right there without any extra mods...there is more than one way to skin a chicken
Old 07-26-2010, 04:32 PM
janaka's Avatar
mods in sig
bad headers are causing low #'s IMO.
224/224 cam
fast90 intake and TB
1 3/4 hugger headers.
was 366 before the intake and tb.
Old 07-26-2010, 04:36 PM
docwyte's Avatar
I plan on doing a cam, headers and intake. The motor is going into my Porsche 944 (soon to be not turbo).
So I have to run headers and an intake to get the motor to fit. It's just a question of what cam I need to run and if I need to replace the stock intake manifold and throttle body.
I don't have a lot of hood clearance to play with, so any intake manifold that's higher than stock will be a tough fit..
Old 07-26-2010, 04:45 PM
NVR_SPDS's Avatar
The LS6 intake would be your best bet on the intake manifold, but full bolt ons should get you close to what your goals are.
Old 07-26-2010, 04:48 PM
Z28_LT1's Avatar
Bolt-on's will get you right there with a little bit of tuning. I don't think you'll need a cam for that...
I would see how close you get with bolt ons. If you have a little more room to play around, I would do a minor port job on the heads and call it a day.
Old 07-26-2010, 05:02 PM
LS1-NAVY's Avatar
i would do lid, headers, ls6 intake and a 224 cam then put some 4.10's in it to keep your numbers lower and u will be in your powerband all the time
Old 07-26-2010, 05:09 PM
ULTIMATEORANGESS's Avatar
full bolt ons will get you there. if not you can add pullies, or a cutout and a EWP to get what you need.
Old 07-26-2010, 05:44 PM
docwyte's Avatar
I've heard that most of the 01-02 camaro/firebird LS1's came with the LS6 intake. That true? How can I tell by looking at the motor to see if it already has the LS6 intake?
I'm definitely doing a cam, as once I put the motor in the car I won't have access to it without taking apart the entire nose of the car.
Who do you all recommend for tuning?
Old 07-26-2010, 05:59 PM
Blackhawk777's Avatar
As far as looking, you can't really without taking the intake off and looking at the underside of it. I'm pretty sure the flat style is the LS6 intake. I do know all 2002 models have it, not 100% about all 2001 cars though.
Old 07-26-2010, 07:33 PM
DCC!!'s Avatar
does ur intake have a egr hole right behind the tb flange if not it is a ls6 intake if so its mostlikly a ls1 intake
Old 07-26-2010, 07:49 PM
docwyte's Avatar
I haven't bought a motor yet. I'm still in the research phase and want to get the best one possible.
This way I can hopefully buy a motor that already has the LS6 intake, etc...
Old 07-26-2010, 07:56 PM
LS-1Z28's Avatar
lid, headers, intake, and a good tune can get you there
Old 07-26-2010, 07:57 PM
LS-1Z28's Avatar
Old 07-26-2010, 08:14 PM
DCC!!'s Avatar
then yes look for that and 243 heads and you shou;d have a good little doner motor
Old 07-26-2010, 08:22 PM
docwyte's Avatar
Total noob question...
How can I tell if it has 243 heads and what makes them better?
Old 07-26-2010, 11:09 PM
caseypryan's Avatar
They have the casting number stamped on them. If your car is stock with will have 853's (98-00) or 241's (01-02). The 243's flow a bit better. But mainly people look for the 243's off LS6 corvettes because they have sodium filled valves and better valve springs.
Old 07-27-2010, 02:50 AM
DCC!!'s Avatar
you might wana go ahead and get a ls6 and shrow some headers on then you should be close to ur mark with some other stuff
Old 07-27-2010, 06:50 AM
SladeX's Avatar
Longtubes, LS6 intake and true dual exhaust brought me to 344HP.
TR224 0.561 lift Cam + underpulley brought me to 373HP.
A bit of tuning brought that up.
Rocker arms + no tick pushrods of proper preload + 3.9 gears may balance out.
I think the cam is the simplest route for good power or every bolt on that exists.
Old 07-27-2010, 07:22 AM
smg267's Avatar
Just buy an ls6 longblock and exhaust and call it a day. Most places sell complete pullouts with trans for a fair price.
