Coolant passage bolt on side of block?
I noticed a small coolant leak coming from my engine, so got underneath and it seems like its coming from a star-head screw or bolt on the drivers side of the engine behind the alternator. I guess it leaks from the engine expansion as it heats and cools over time as the special sealant wears out. Anyways, my question is does anyone know what size that bolt is so I can go buy the right tool for it. Thanks
KC
KC
No mine is on the driver side of the block. And I don't need the plug, it's there and fine. The sealant around it has worn out. I have a tube of sealant for it, I just don't know what size the plug is so I can go buy the right tool to get it out.
dude what the **** are you talking about?
If it is the ALLEN HEAD PLUG, which for some reason is on the drivers side head as opposed to the correct place on the passenger head, then you will use a 17mm ALLEN WRENCH to remove the ALLEN plug. It's not called "star shaped plug" for a reason.
Also any sealant will work. Some would say loctite, some would say teflon tape, but i highly suggest ThreeBond 1194. Best investment you'll ever make, besides a "car work for dummies" book.
You can see the driver side engine mount there on the right before the plug. But as your dumbass can even see, its NOT on the head, its on the block, like I said! And no **** its not called a "star shaped plug" for a reason. But you know, your right theres no such thing as one of those. OH WAIT!
Damn, I may not know the exact name of it, but i described it best I could.
Ive done all the work on my car for over 5 years, but I dont know everything, thats why I ask these questions here. So if you have nothing better to do than try to talk some lame ****, instead of posting in my thread, go **** yourself while reading your "car work for dummies" book you tool.
Okay, since you seem to be getting some smart *** remarks....
you would need a ridiculously large and expensive allen/hex head for the plug.
The easiest and cheapest thing to do is go to the hardware store, metric section, and buy a few different sized large hex bolts/nuts whose heads look like they would fit into the plug.
Go home, and test them out. Double nut the bolt whose head fits into the plug. Then you can then use a regular crescent wrench on 1 of the 2 nuts to turn the assembly.
PS. "double nut" or "jam nut" means to put two nuts on the bolt, then taking two wrenches, and turning them against each other, so they jam up. This way, you make an assembly that is one solid piece.
Guys the thread is to help each other base on your experience, knowledge or hypothesis (when you don't know) there is no reason to be a smart ***. FBodyPerformer take it out install teflon tape or ThreeBond 1194 reinstall it back and problem solve. Here's a pic of a really smart *** Dunky
THANK YOU! to the last couple people that came in with the knowledge (and maturity) I needed and all I was looking for, a simple size of plug. I'll go up to sears and pick that up tom.
Now I have another question. My friend that works at a carl black dealer as a tech down here, gave me an aluminum RTV to use, said that would work on it. Can I stick with that or do the Teflon tape or that threebond 1194? I was told GM used a special sealant on those plugs b/c like I said, it has to be flexible enough to hold under pressure as the engine expands and contracts from it heating and cooling.
I would just use liquid teflon sealer and never give it a second thought. (i use it all the time) but that's just me and I haven't used the threebond or the other stuff you mentioned much less even know what they are so IDK what to tell you there.
Glad I ran across this. I hope that's all that's wrong with mine. Btw, I ran across another post a bit ago talking about a similar issue and it gave info on the bolt as well.
https://ls1tech.com/forums/generatio...plug-help.html
Guess all thats left to do is check where its leaking now. Too bad I already bought and installed a new water pump.
