Slight scratches on bottom or head = re-milling?
I bought some Patriot Stage I 5.3 heads, and in the process of moving them around, they have gotten some slight scratches on the bottom of one of the heads. Will I need to get them remilled to clean this up? Thanks!
No this should not be a issue, if you are using multi layer shims head gasket than pay close attention to how deep they are and what areas these scratches connect when referencing head surface. Fel Pro composition or other of this type will fill those slight voids when clamped down.
before you put those heads on you should have someone check them out. there are alot of people with some major oil consuption problems now. better to have them checked out now before you wind up having to pull them off.
its right in this post just go right to the end of it. also do a search there seems to be alot more cases of it. https://ls1tech.com/forums/generation-iii-internal-engine/131499-hp-missing-g5x2-cam.html
