What are the specs on the G5X3 cam?
?????????Why is it such a secret? Ive heard it will fit with stock heads on a 114 lsa, but will it fit on a 112. And if it wont fit on a 112, can someone give p/v clearance on a 114 if they have it? thanks
I put one on a cam doctor a few weeks ago, but I'm not at liberty to say. Aw, screw it, the #'s aren't patented or anything. Here ya go:
274/282 .694/.683 98 LSA, 22 degrees of advance ground in. But it fits if you remove the entire piston assembly out of the car.
Well i plan to run a larger LSA for other reasons and would like a lot of duration and good lift for Stage 3 LS6 Heads. This is a Cam im considering. Why are its specs hidden, or is this a joke?
Shawn
Well its because if people knew what the specs were and if it wasnt a propritery lobe..then you could just order the cam from Comp, Crane,Lunati...etc and skip the middle man
LSX Mechanic
Originally Posted by Beast96Z
I'll never tell. Clearence with the X3 114 will be .205". .220 is reccomended for a safe clearence. I would imagine the X-3 112 would be in the .180"s. Some do it, but it is way to close on a 112. The 114 should be fine.
Originally Posted by Damian
Holy **** ....That's required clearance? Are you sure you got those #'s right?
That is using the "piston drop" method. You measure, on a flat surface, how far an intake valve drops before it hits the surface. (Say .160) Then you add gasket thickness (say .060 for stock MLS gasket), add the two together and you have .210 clearance. If, for example your "drop" number was .100 and your gasket was .043, you'd need a .067 flycut to get the same amount of clearance. I'm pretty sure you need .200 on a 114, .220 on a 112, but I'm not positive... [Clearances given are for G5X3 as this is what I've been calulating for ...]
Shawn
6 Second Club Moderator
SN95 Director
Originally Posted by jrp
if its a propriety lobe then why did they release the OG g5 cam and the x2 specs :shrug:
i dont think they ever release the x2 specs...somebody let it slip when they werent supposed to
SN95 Director
well, look how popular the x2 is depite the fact that the specs are out, i dont think that its hindered the sales of the cam.
well my hole thinking is, if you know what stock p/v clearance is then anybody can call comp or whoever and figure out how big of a cam you can actually put in it. I can tell you i am i the market to buya cam, and ill be damn if i going to buy the cam and not know the specs, thats retarted. i mean doesnt the cam come with a CAM CARD???????????????so if you dont tell what the specs are now, then they will know when they open the box,right
I will never install a camshaft without a cam card from the manufacturer...I still to this day have never installed a cam without degreeing it...sure i can find out the intake centerline and all by degreeing...but who knows what the centerline is reccomended to be?I think the G5X cams are making awesome power...but without a cam card or atleast a reccomended centerline there wont be one in my car or any of my customers cars..."dot to dot" just doesnt cut it for me especially when clearance is that close...I like all of LG's stuff and I actually reccomend it to people...but i couldn't force myself to install one without a cam card.
The following users liked this post:
ZoDDy (03-12-2020)
