Can an older 350 block be converted to an LS1 or Lt1 ?
i have a friend who will give me a 350 engine and a .60 over piston kit and was wondering if I could use this block to build an LS1 or LT1 engine for my 95 firebird. will the intake and oter ls1 parts bolt on? I want to put an Ls1 or Lt1 engine in to replace my V6 but if I could use his stuff it would be cheaper. please give me some input on this. If it cant be done can it be converted from a carb to fuel injected
Originally Posted by BLKTA
you can't interchange blocks between an old school SBC and the LS1; they are completely different.
So which one would be better to build?
SN95 Director
the LS1 is still comming into its own and makes great power but unfotunately you get raped by the price of parts .
You can build an old school SBC and bolt it right up to your existing motor mounts.
Block wise the LT1 and SBC are virtually identical, you run into some cowl clearance issues if you want to run a carb set-up though. Nothing an air saw can't fix
Depending on your budget I would either build the SBC or put in a LT1 if you are right on dough. As stated above, the LS1 is still coming into its own, and the aftermarket parts for it are still on the pricey side.
Just my .02, Good Luck!
Like everyone always says, it all depends on your goals and your budget.
[QUOTE=Nick@AP-Engineering]You can build an old school SBC and bolt it right up to your existing motor mounts.
[QUOTE]
ummmm arent the coolant flows reversed on the lt1
[QUOTE]
Also there are some differences in the block. The water jacket passages are different in the block as the timing cover and water pump provisions. The deck surface is different where the water jacket passages are. The LT1 heads will physically bolt on to a regular SBC and vice versa, BUT they will NOT work without modifications to the water passages on the heads. (requires welding and filling) Also the intake manifolds are different. On an old school SBC, water passes though the intake manifold, on an LT1, it does not. It's routed through the water pump housing.
Steve
