ATTN: cam gurus, CA smog legal cam L@@K!
Just looked and you can't do lower than a 220 on XE-R lobe. So givin that a 220/220 like TSP offers would make for a good cam. Overlap would be -6
Whether or not it will pass smog is also dependant on tune more than overlap so keep that in mind
99Bluz28, my cam spec is 224/230 114LSA .581/.588 lift. According to the web calculator my cam has a -1* overlap. However, b4 I bought this cam I consult another cam expert here. He said I should pass CA smog no problem. What's your opinion?
Well if anybody knows what makes the AFR 205 heads Ca smog legal, I would like to know...I am wondering if my PRC heads will be a problem...I tried to go real mild on this build...my fingers are crossed...Also contemplating e85 as its available for $2.7x right up the street...hmmm
What part of SD are you in?..I am in Mission Hills
