T Rex cam - who runs it DD - how does the car run in general ???
Old 11-01-2010, 11:31 AM
AAK z28's Avatar
Default T Rex cam - who runs it DD - how does the car run in general ???
Before I install it I just wanna know how the car runs with the cam and if I make good power?
Old 11-01-2010, 01:42 PM
AAK z28's Avatar
Anyone run this cam at all?
Old 11-01-2010, 01:46 PM
JustAnotherLS2's Avatar
I know a lot of people run it, but IDK about DDing it. I wouldnt, but thats just me. Drivability is more in the tune.
Old 11-01-2010, 04:58 PM
AAK z28's Avatar
I live in michigan so it would only be a summer car I have another vehicle. Its not really a DD more of a drive around and pick on mustangs with car and cruise around
Old 11-05-2010, 01:11 AM
camaroz280294's Avatar
I have a t-rex in my DD 02 z28 M6. The car ran great till the piston hit the valve and broke the lifter. lol. I liked the t-rex for the most part. My car which is basicly stock and made 400 rwhp. and was a great to mess with mustangs in. The main problem i had with the cam that it made no power till 3500 rpm then it would blow off the tires. even running street slicks. I didnt mind the jerk at a low rpm but with 373 my car would jerk sometimes at 60mph+. i got used to it. when i got my motor rebuilt i put a smaller cam in the car. but if i had to do it again, i would put the trex back in it.
Old 11-05-2010, 01:29 AM
NoGamesLS1's Avatar
I daily drove mine for some time, but it was in a stroker so it may have felt milder. FWIW I talked to Shane at thunder racing and he ground a custom cam for me. I ended up making more peak hp and a ton more torque (over 400rwtq from off idle to 6k) with a 228 intake lobe. You can definitely hear the cam, but it is pretty mild. You may want to consider something that makes more low end power especially with a M6. But either way I really liked the trex. I definitely miss the sound of it. Sounds like the world is coming to an end at WOT.
Old 11-05-2010, 01:31 AM
BennyB's Avatar
with a good tune you can dd the cam, but i wouldnt do it.
Old 11-05-2010, 11:06 AM
LSX Mechanic
Damian's Avatar
I just tuned a car with the TREX and 4:56 gears. It drove surprisingly well, but I'm positive the gears had a lot to do with it. I personally wouldn't DD it.
The TREX is also old technology. You can run a much smaller cam with better lobe designs and make more power under the curve without giving up much if anything up top. And it only takes one good misshift to marry a piston to the valve with that cam.
Old 11-05-2010, 11:32 AM
Randy WS6's Avatar
I had one also, Like said you need a good tune and the T-rex in not factory stall friendly
