Ls1 stroker kit possibilities
Old 11-03-2010, 03:04 AM
1991ls13's Avatar
Default Ls1 stroker kit possibilities
Ok, I`m a little worried about my searching abilities cause most forums and discussions I`ve come across say i cant stroke my ls1/ls6 04 aluminum gto motor cause its not an iron block.
Now i know with the stroker kits for the small block, they come in a few sizes, 383-408-427. I was going to go with the 408 cause i will be dd it and 383 isn`t enough and 427 is a beast beyond belief.
My current set up is some bolt ons and a tv2 cam and ls6 stg 2 prc heads from tsp. Right now I`m at 409whp and 368tq. A modern gain.
Am i sh8t out of luck or is it safe for me to do a 402-408 stroker. I`ve seen a 383 one when i google it but I`m really not trying to do a measly 383. I really dont want to just rebuild it and then do a SC or turbo.
Also a side note- with my current set up( cam choose ) how will it act with a 408 if its possible and safe to stroke it? Will it seem less aggressive since it has bigger qubes?
Old 11-03-2010, 05:54 AM
Grifter's Avatar
I have a similar thread going:
https://ls1tech.com/forums/generatio...-99-block.html
From what I've read it seems the most you can safely stroke an LS1 is to a 383, anything bigger and you'll want an iron block.
Old 11-03-2010, 10:30 AM
reeperz28's Avatar
I've got a 2002 ls1 block that I'm planning the same with and I wanted more cubes as well, but ended up deciding with the 383. Due too the aluminum block would need to be resleeved with special sleeves to achieve your 408 to be reliable .
if you wanted to stay aluminum I would find a ls2 block and start with that and go 402 from tx speed I have seen a few ls1 383 pass the 500 rear wheel mark but with some of the healthiest head and custom cam combos. And I have a friend who has a iron 408 with a ms3 cam and it sounded like a gm hot cam practically with the more cubed and stroke so a bigger cam is def reccomended
Old 11-03-2010, 11:16 AM
LS1TECH & Trucks Sponsor
Sales4@Texas-Speed's Avatar
Like these guys said, the biggest you can safely go on an LS1 aluminum block is the 383. There is not enough sleeve to go any larger.
If you go 408 your current heads would work fairly well but you would want a larger cam. The torquer v2 would be a pretty small cam in a 408 c.i. motor.
Old 11-03-2010, 01:20 PM
SOMbitch's Avatar
Either find a cheap iron block and go 40x or stroke your LS1 to a 383. I have seen a LS1 396 kit somewhere but never seen one in a car.....
Old 11-03-2010, 01:44 PM
1991ls13's Avatar
i`ve been thinking about just selling my complete engine and buying a iron lq4 and sc turboing it. But i dont know if i`d get the price i`d want. What does something like this go for?
Also what would be the average gains from a 383? Ive gotten mixed numbers from searching, ranging from 40-80hp. So im not sure what i`d expect.
Old 11-03-2010, 01:54 PM
NoGamesLS1's Avatar
Here is a link to my 393 (3.9X4.1), stock block. Motor was built almost 5 years ago and has around 25k miles on it. The dyno numbers are from just a couple weeks ago. I have only seen one or two of these setups on here, so they are pretty rare.
https://ls1tech.com/forums/dynamomet...acing-cam.html
Old 11-03-2010, 08:02 PM
1991ls13's Avatar
^ very nice. your in sac which is very close to me too. where did you find the kit and how much?
Old 11-03-2010, 08:08 PM
NoGamesLS1's Avatar
I bought the assembly somewhere off the internet. It is an Eagle crank and rods with Probe pistons. I think it was like $2000 shipped. Then I had a machine shop put it together. It's just a 4.1" crank instead of the 4.0". Where are you located?
Old 11-03-2010, 09:45 PM
1991ls13's Avatar
thats not bad, Im located in nor cal. Just north of sac.
Old 11-09-2010, 12:37 AM
1991ls13's Avatar
hows the drive ability?
Old 11-09-2010, 03:28 PM
NoGamesLS1's Avatar
It is pretty good. Sometimes I get a light bucking when it is cold going over speed bumps, but that is most likely a fueling issue I need to track down. It is smooth. I can come out of a 20mph 1-4 shift (about 850rom) with no issues. It gets great highway mpg (27-29) but pretty bad in town (14.5-15.5).
Old 11-10-2010, 08:19 PM
1991ls13's Avatar
same here with my current set up. Anyways if you ever remember where you got the kit from please let me know on here or pm me. I would greatly appreciate it.
Old 11-10-2010, 11:15 PM
NoGamesLS1's Avatar
http://www.adperformance.com/index.p...roducts_id=744
Old 11-15-2010, 02:20 PM
1991ls13's Avatar
I found this on the good ol internet. Anyone see this before? Doesnt show a price so im guessing thats a bad sign for its probably expensive. Has options for a 395...guessing 393-395-396 are all the same basically.....
Old 11-15-2010, 03:04 PM
rooster18's Avatar
dont mean to hijack but im curious, i see that this kit is offered for a 3.905" bore size. when you do this kit if you are using a 5.7 ls1 do you have to bore the cylinders to get to this or is it new sleeves. kind of a noob question but ill never know if i dont ask. also what is the biggest bore you can go on an ls1 with stock sleeves and still be reliable? can you run this kit with the stock bore and if so what kind of power difference would it be between it and the 3.905 bore?? thank you and sorry
Old 11-15-2010, 03:25 PM
david vericker's Avatar
The 3.905 bore is based on a honed not a bored cylinder,this equates to one additional cubic inch over stock. The 4" stroke accounts for the additional 36 cubic inches = 383 ci stroker engine or 393 ci with a 4.10" crank. I think the largest cylinder bore on stock LS1 based sleeves is 3.910 which in my opinion is a last resort size (bore) to clean up scored cylinders.
P.S. Don't believe every dyno result published...all dyno's are not created equal.
Old 11-15-2010, 03:55 PM
rooster18's Avatar
thanks man, you cleared it up a lot for me and i've heard this about dynos. i also see where people have two numbers listed, one for mustang dyno and one for another. the mustang is lower always i believe. what is up with that??
Old 11-16-2010, 11:15 AM
1991ls13's Avatar
they are just like that. Those stang dyno`s from what i`ve seen always dyno anywhere from 15-30hp less.
Back on topic please.
Im really not trying to go 383 cause thats a waste imo. so im trying to find the 393-6 for the cheapest price. looking all over the internet for one cheaper then the 2100. I`d be sold if i could find one for like 1900 or something.(cheap ***)haha
Old 11-17-2010, 10:39 AM
I wouldn't want you to waste your money on a 383,but do some research on the pro's and con's of a 4.00" stroke vs the 4.10" stroke. Give Eagle a call directly and talk to to their tech guy's...I did.
Quick Reply: Ls1 stroker kit possibilities
