Should I Get a New Oil Pump and Timing Chain?
This summer, I might be adding S2 heads. Should I at that time add these components? Will kind of be on a budget, but I also don't want anything to break on down the line. The car now has 26.7 thousand miles on it if that helps.
LS1Tech Administrator
Received 1,492 Likes
You're in there anyway, and with 26K you might as well change them I guess. I changed my pump because I was seeing slightly below average PSI on the stock one. I didn't bother changing my timing chain because it only had 5K miles on it.
I have no issues with using a new(er) stock chain. Our last club project LS1 car that went mid 10s on the stock chain, under boost & N2O, shifting at or above 6900rpm. A piston eventually melted but the stock chain was fine
