TPiS Modded Intake with LS7 TB - Help Please
Old 12-20-2010, 06:39 PM
jpoole's Avatar
Default TPiS Modded Intake with LS7 TB - Help Please
I put a TPiS intake modded for a 90mm TB and a LS7 TB on my CTS-V with a LS6 and am getting Reduced Power Mode when ever I get on it. Does anyone know what is causing this and how to fix?
Thanks, Jeff
Old 12-20-2010, 07:21 PM
Russ K's Avatar
You need to raise the P1514/P0068 Error table to match your WOT airflow (in g/cyl)
Russ Kemp
Old 12-20-2010, 07:26 PM
jpoole's Avatar
Thanks Russ, do you know where that is in HP tuners and aproximately how much?
Old 12-20-2010, 07:45 PM
Russ K's Avatar
Engine Diag>General>TPS Sensor>Cal Airflow-P1514/P0068 Error.
Start by multiplying the entire table by 1.25. Then do a WOT scan logging Dynamic Cyl Air (g/cyl). Just make the P1514/P0068 table values slightly higher then your scan values.
Russ Kemp
Old 12-20-2010, 07:49 PM
jpoole's Avatar
Thanks Russ, found the table and have increased by 1.25. I am gonna install the tune and see what happens. Really appreciate the help!
Old 12-21-2010, 07:57 AM
jpoole's Avatar
Well, did something bad. Went to flash and was having trouble connecting so i tried to write full pcu in test write mode. It connected but was going to take 15 minutes so I unplugged. Now car shows low battery error and won't turn over or even try.
Old 12-21-2010, 09:00 AM
LSX Mechanic
Damian's Avatar
That was a major no-no. You probably just killed your PCM.
Good luck.
Old 12-22-2010, 02:52 PM
jpoole's Avatar
Update: All is good.
Battery in car was bad and once replaced everything is fine. According to HPTuners support, they don't know of a way to ruin a PCM when in "In-Active Test Mode" like I was.
Also, made the flash today and it fixed my original issue.
Old 12-22-2010, 05:49 PM
raven154's Avatar
Man I need to get hptuners. Or find someone around here that has it. My car needs some tuning too.
Old 12-22-2010, 05:55 PM
jpoole's Avatar
Yea, I just found a shop and did a dyno tune. I use HPtuners to import and mod the dyno tunes when I need. I can't tune cause I am a novice.
