FMS 226 or TSP 231/237?
Ive narrowed it down..finally Will run either cam on STOCK heads through a SS4000 with a moser 9" with 3.70 or 3.90 gears(still up in the air about that one)
Now on to the cams...either the FMS 226/226 .575 114 lsa or the TSP 231/237 .598/.595 112lsa. Mike H. has the 226 and has posted up some great times in his "cam only" set up. However he is running a bigger stall (pt4400) and 4.10's
Dont know many people running the 231/237 in an A4 so i dont have much of a comparison there. Also, many of the dyno numbers between the two are pretty similar, but most of the numbers and powerband ive seen for the TSP cam have been through an M6 or ported heads or both.
So, I need your opinion on the "better" of the two for my application.
Thanks for your input.
Originally Posted by foff667
thats what i went with should have it installed by some time next month
Originally Posted by wrencher
Good point, that's exactly what I was thinking?
Yes, the TSP cam is a bigger cam, that is a given. This cam would be pushing the envelope as far as cam size for what im looking for in my application. But with all of the feedback on this cam, I believe it would work well in a daily driver with the previous parameters given in the set up I would like to run it in. I also believe this to be true for the FMS 226 as well.
So, maybe the question I should be asking is if the added duration and lift as well as the tighter LSA of the TSP cam worth enough extra power over the FMS 226 to justify the shorter valve spring life and a possible drivability factor (as compared to the 226)? Also, being that I have no times for a "cam only" TSP 231/237 in a similar set up to Mike H.'s, then would the bigger TSP be worth a shot so that i would have to find out on my own? If that were the case then maybe I would go with a custom grind since I would be throwing a few variables in the air anyway?
Any thoughts?
wrencher
Well either cam you'll be in the same bout w/springs 575 or 595 pretty close #'s there.
I would replace springs just as often w/either one IMO.
Why not call & talk to Allan & get his thoughts?
If this is a daily driver A-4 is the 231/237 what you want?
It's a great cam, but your gonna have to sacrifice one way or the other.
!LS1 11 Second Club
Yeah, the TSP231/237's lobes are even softer than XE lobes, let alone XE-R lobes. So it's not too hard on springs as one may believe by the lift numbers alone. The big cam is very daily driveable.
!LS1 11 Second Club
How exactly would it be a "personal" preference? Isn't this a technical matter?
Not flaming, just would like to know how it's personal while not providing an argument one way or another?
!LS1 11 Second Club
Am I asking people to pick my girlfriend, or to provide info on possible girls? He is!
Why don't you contribute your knowledge as to how the Futral would be beneficial.
I didnt say the Futral would be beneficial..... I said it was personal preference.
MY opinion would favor the FMS cam. This is likely due to the fact I have seen FMS cams in action over and over again. They perform. I only have one experience locally with the TSP 231/237 and I didnt like the power under the curve. WIth this guy having an auto, that may not play an important role, depending on his stall.
Given the 2 cams, I would also put drivability and tuning in favor of the FMS cam for an auto. I know lotsa guys have the TSP in their A4, but drivability is also a matter of personal preference....
BTW, second hand info on girls is about as accurate as most of the info you get off the internet.... Guys will rip on a girl just because they got rejected... Ask Bad Andy about that one
!LS1 11 Second Club
Well, I must say the above was much more informative than "personal preference." Was that so hard to type in the first place? You do have the Futral website in your sig, so I thought you may have had a bias towards their product, and I wanted to know more about their product.
To contribute to the info, here's a link to my dynograph with the TSP231/237 with my old exhaust setup. The peak numbers read too high, as the output is more like 400rwhp even, but the curves are informative.
Stock heads, M6, 4.10's in 10 bolt.
http://home.att.net/~carlos.ramirez1...2/site1003.jpg
One can order the TSP231/237 on a 114, but the TSP guys put the 112 in A4's all the time with proper stall.
!LS1 11 Second Club
Originally Posted by Cammin BeaSSt
Yea, it was... Personal preference is two words. I had to type a damn paragraph to get my point across thanx to you....
Oh yeah, I picked my girlfriend out about 15 years ago. She was a keeper.
also keep in mind the tsp cam doesnt have the fast ramp lobes on it so as far as spring life goes it might be a toss up if the FMS cam uses harsh lobes
I asked candy about how long 918's should last with the FMS 226 cam, she said 1 1/2-2 years, though one of their friends has been daily driving his for 40k miles and has no problems so far.
