valve spring lift vs ms3 cam
hey wussup guys I have some valve springs that are rated to .600 lift from texas speed. the 918 spring if im not mistaken its been a couple months that ive had them but im getting my cam put in this week. I was wondering with those spring rated to a .600 lift will me running the ms3 cam with a .603/ .609 113 lsa be safe. Thanks alot
The only engines I build are my own. As a do-it-your selfer I try to choose components that are well within the recomended specifications even if it costs more to do so. So when the manufacturers sets a maximum lift I treat it as such. That particular cam carries very well and makes power out to 6,800 rpm - it invites high rpm operation. Since I do like changing valve springs frequently, I would choose springs with some "headroom" in the specifications.
^agreed they set spring specifications for a reason. Im sure you could prolly get away with it for a little while, but i dont think its something you should risk. Get springs that are rated to deal with the lift specs of your cam.
well the story is that I bought alot of stuff from texas speed all at one time and I ordered the prc dual springs .650 lift and I got everything in the mail except for the springs retainers valve locks etc... and I called texas speed and they said they were back ordered. and about a 4 days later I get a package from them with springs that wasnt duals they were single. I didnt think too much of it because I had alot of stuff going on at the time but now that im finally putting my cam in I took a longer look at them and I knew something wasnt right and I threw the box away so I dont know if their the 921's or what and they dont say it on the spring so idk. Im not going to say their 918's because I really dont know but I was starting this thread to see worst case senario if they were 918's would they be safe. But seriously I dont know if their 921's or not and its deffinately too late to ship them back it was about 5months ago so im stuck on what too do.
The Comp 918 is a single spring, the Comp 921 is a dual spring with the same specificiations as the PAC 1221.
Edit: Additional research indicates that the Comp Cam website lists the maximum lift on its current 918s at 0.625" even though the Texas Speed website continues to list 918s as having a 0.600" maximum lift.
You might want to check with Texas Speed as to whether there is a real change in the hardware or just a different view as to their reliable limit.
