I have a 99 trans am.. whats the best all around cam?
Old 01-06-2011, 04:10 PM
firehawk68mcleod's Avatar
Default I have a 99 trans am.. whats the best all around cam?
I have a 99 trans am and its alll basically stock.. i have longtubes y pipe basic bolt ons .I have a lifter tapping .. so i figured while i was in there why not throw a cam in it... .. So whats a good all around cam for my stock heads and lower end... keep in mind i want to keep it fuel efficient.. nothing radicle. Let e know thanks
Old 01-06-2011, 04:19 PM
PREDATOR-Z's Avatar
220/228 .581/.588 111+2 lsa
Old 01-06-2011, 04:25 PM
Is that a choppy cam? would i need to change the springs... i have a set of ls2/ls6 springs would those work
Old 01-06-2011, 04:33 PM
PREDATOR-Z's Avatar
It has a light lope to it, 2* overlap. No the LS6 springs will not work right. You need either Comp beehive 918 or Pac 1518 at correct height.
Old 01-06-2011, 04:36 PM
So, i need the cam... so $400 give or take, springs... $200 give or take and lifters .. i guess a new set of gm lifters would work?$125 plus head gaskets.. what kinda power gains with i see? something similar to a Z06 5.7
Old 01-06-2011, 05:14 PM
PREDATOR-Z's Avatar
Do a port and valve job on your heads (since they are off) from AI and you'll make in excess of 400rwhp
Old 01-06-2011, 05:37 PM
garygnu's Avatar
if your mileage is not too high you can use your current lifters.inspect them closely for any wear.
Old 01-06-2011, 05:39 PM
i have a set of ls2 lifters with only 30,000
Old 01-06-2011, 07:52 PM
JRENIGAR's Avatar
Id replace the lifter trays just for safety, after all, they only keep the lifters from turning on the cam. For around $30 you cant beat the safety factor.
Old 01-06-2011, 07:56 PM
YEah thats true and i get gm discount so maybe less
Old 01-06-2011, 08:03 PM
Captain Double Post
BOBS99SS's Avatar
yeah I would have the heads done while they are off,just call TSP and get one of there cam packages
Old 01-06-2011, 08:11 PM
I would just build this car with ls3 heads and a cam if i was wanting tons of power but this is my driver... Im building a 68 camaro ls2 D1 procharged to go fast lol . This is just my nice efficant, reliable, driver lol I dont want to put too much in her just wanted to freshen her up while i was in there.
Old 01-07-2011, 06:18 AM
PREDATOR-Z's Avatar
You can't fit LS3 heads on a LS1 with stockish bore. Still I would work on the heads while they are off. Or at leat a set of fresh 243/799
Old 01-07-2011, 07:49 AM
Yeah i remember seeing that bore size probelm on a thread on here... Well maybe if i come across a low mile set of 243s i might slap them on.
Old 01-08-2011, 10:55 AM
Isolde's Avatar
Hey Pred-Z,
Why would you run that cam over the LSr 269?
http://www.compcams.com/Company/CC/c...csid=1400&sb=0
Old 01-08-2011, 08:59 PM
TVWilkes's Avatar
A 3/4 race cam, jk, lol. It will be hard to beat a 220-224 cam.
Old 01-08-2011, 09:31 PM
Tommyv8's Avatar
If you're not sure of exactly what you're looking for then just get a Thunder Racing TR224 cam and call it a day.
Old 01-08-2011, 10:04 PM
brian_rs/ss's Avatar
eps 222/226.
https://ls1tech.com/forums/dynamomet...241-heads.html
Old 01-08-2011, 10:11 PM
zspot98's Avatar
Gotta add pushrods to that list also. Not too sure why you're listing head gaskets? You will need a gasket kit for the front of the motor, plus a new bolt for your balancer.
Old 01-08-2011, 11:09 PM
99Bluz28's Avatar
Originally Posted by brian_rs/ss
The EPS 218/226 would also be a good choice, or even a 220/220.
Quick Reply: I have a 99 trans am.. whats the best all around cam?
