fast 102 t/b to tsp 100mm maf
Old 01-06-2011, 11:03 PM
35th camaro's Avatar
Default fast 102 t/b to tsp 100mm maf
What are you guy's using(bellow) to couple up your 100mm texas speed map to your fast 102 t/b, and does the texas speed maf couple up to fast toys 104 air lid directly with no problemes?
Old 01-06-2011, 11:09 PM
Magnet's Avatar
Probably better suited in the gen III external section.. The MAF is suppose to fit right in the lid and do a search for "alternate smooth bellow" I would post a link but I'm on my phone.
Old 01-06-2011, 11:20 PM
brian_rs/ss's Avatar
intakehoses.com
Old 01-27-2011, 06:27 AM
dferg99's Avatar
Yeah that mate up but it took a lot of cutting and bending and sweating to line it up. I had used a custom bellow. This is a Fast 102 Intake, 102 TB, 100 MAF, 104 Fast Toys lid
Attached Thumbnails fast 102 t/b to tsp 100mm maf-img00156-20100701-1815.jpg   fast 102 t/b to tsp 100mm maf-img00157-20100701-1815.jpg
Old 01-27-2011, 06:33 AM
garygnu's Avatar
air flow systems ,or the plumbing dept. at home depot.
Old 01-27-2011, 10:23 AM
thanks for the pictures, i have same set up, my maf and lid are on the way, should have by monday, they say that there is a rubber coupling that comes with the maf, has anybody tried that to join to the t/b?
Old 01-27-2011, 11:29 AM
Engine_HP's Avatar
22 degree 4" silicone hose, thats what i have with the FT104 and 4 inch pipe in place of the MAF.
Old 01-27-2011, 11:55 AM
Sommer86's Avatar
Nice set up Ferg! I'm doing almost the exact same. What did you do for the pigtail from the MAF to the harness? (mainly I'm asking what you did for the IAT sensor) did you get a new pigtail that went from the MAF and split into 2 different ends? (1 for the IAT and 1 for main harness?)
Old 01-27-2011, 11:10 PM
airforcemanss's Avatar
I also need a bellow for my 102 setup. are you guys putting the 4" bellow in boiling water and stretching it on?
I'm new to this...but i believe i've seen someone punch a hole for the IAT sensor into the coupler on here...how does that stay stable?
sorry for throwing this in here but this is in relation to the thread. i don't want to start another thread.
Old 01-27-2011, 11:14 PM
Turd Gen Guy
1nasty86's Avatar
Whatever you get make sure it is 4' id. My tsp 100mm maf came with the 2 ended pigtail.
Old 01-28-2011, 12:20 AM
Sommer86's Avatar
Thanks.
I have a Callaway and since it's a Vette part, it came with a 5 pin- 5 pin. Like you, I need a 5-3&2. I just saw that Lingenfelter sells them.... $24.
Anyone wanna trade pigtails for a 5-5 pin?
Old 01-29-2011, 12:07 AM
dferg99's Avatar
Actually I think my tuner removed the IAT. My setup has changed since the picture because I also added the 102mm nitrous plate. When I get my car back from the shop I will put more pics up to see what they did.
Old 01-29-2011, 03:26 AM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
I could see someone ending up with a 4'' OD and having a hell of a time getting it on there.
Old 01-29-2011, 02:27 PM
Turd Gen Guy
1nasty86's Avatar
oh god! thatd be a real pida!
Quick Reply: fast 102 t/b to tsp 100mm maf
