Stage 2.5 5.3 heads on a 5.3?
Old 01-08-2011, 10:28 AM
sman's Avatar
Default Stage 2.5 5.3 heads on a 5.3?
Have a 5.3 in my camaro
ls6 intake
longtubes
tr224 cam
3600 converter
3.42's
put down 320/338
Was looking at a set of stg 2.5 5.3 heads. Found a good used set for cheap, was thinking about milling them a bit as well to help bump the lousy compression of the 5.3.
What should I expect power wise? Really looking for that 400 mark.
Old 01-08-2011, 10:45 AM
Isolde's Avatar
I'd also swap in the 4.8L pistons. LM7 = 9.5:1. Milled heads = 10:1, 4.8L pistons = 10.4:1. Milled with pistons = 11.1:1
Old 01-08-2011, 01:38 PM
sman's Avatar
Id like to put the 4.8 pistons in, but I was really trying to keep the motor in the car this year, lol. Ive had it out the last 3 winters in a row, haha. Its got around 100k on it now. I assume I cant just grab some 4.8 pistons and drop them in? Wouldnt I need do all the measurements, hone the cylinders etc?
At that point, id just go get an lq4, seems like itd be more cost effective?
Old 01-08-2011, 03:33 PM
brian_rs/ss's Avatar
lq4/9 with ported 243's(or hell even milled and ported 317's). don't waste your time with that high mileage l33. i mean unless you are just dead set on making a **** hot l33....
Old 01-08-2011, 08:04 PM
sman's Avatar
Its actually an lm7 not an l33. So even less work.
Old 01-08-2011, 09:22 PM
well still. not worth it IMO. u make us much hp as a stock ls1.
Old 01-09-2011, 12:06 PM
sman's Avatar
Im trying to stay on the cheap.
Theres nothing wrong with my motor other than the miles, but there are plenty of HCI ls's with over 100k.
Just wondering how much im realistically looking at picking up if I slapped a set of milled prc 2.5 5.3 heads on.
Old 01-09-2011, 05:28 PM
Isolde's Avatar
I haven't weighed both pistons, they may be a few grams different. But that aside, the only difference between 4.8 LR4 and 5.3 LM7 pistons is that the LM7 pistons have a 7.7 cc dish.
Old 01-10-2011, 08:56 AM
sman's Avatar
Hm, so a set of 4.8 pistons, some new rings, and possibly bearings and were back on the road eh?
Interesting thought.
Is 400 possible out of this thing NA? Or should I just spray what I have and call it a day?
Old 01-10-2011, 11:51 AM
5.3LJimmy's Avatar
I say go for the heads, mill them to 58cc's, and use some 0.040" thick gaskets. This should get your DCR up a touch over 8:1 which is much better than the 7.4ish you currently have. I don't think you will see much over 380 rwhp, but that's a nice bump over what you have now.
Old 01-10-2011, 12:00 PM
sman's Avatar
7.4 I currently have? The lm7 is 8.5 to 1 factory isnt it?
Old 01-10-2011, 01:15 PM
5.3LJimmy's Avatar
The static compression ratio(SCR) is 9.5:1 from the factory. The dynamic compression(DCR) is calculated using the camshaft specs to determine the actual running compression of the engine.
Old 01-10-2011, 02:33 PM
PREDATOR-Z's Avatar
you'll never make 80rwhp with heads, but FI would be the solution. Procharger.
Old 01-10-2011, 03:07 PM
sman's Avatar
Are you going to donate one to the cause? Whats a good used procharger setup run?
Old 01-10-2011, 03:09 PM
PREDATOR-Z's Avatar
Lol, do some research, I'm sure you can find something suitable.
Old 01-10-2011, 03:16 PM
blackedout drop ls1's Avatar
i run those heads. best bang for the buck imo. Why a 5.3 if u dont mind me askin?
Old 01-10-2011, 03:18 PM
I dyno'd 428 n/a with these heads, 227/224 tr cam, ls6 intake, 3:73s, and bolt ons. Of course, I have a ls1.
Old 01-10-2011, 09:11 PM
sman's Avatar
It was a v6 car, and I had a 5.3 laying around sooooo, lol.
Old 03-25-2011, 11:42 AM
Nanner's Avatar
i know i'm bumping up a HELLA old thread... but I didn't want to make a new post if someone else had something similar.
Going for a similar build here (LM7, PRC 2.5 5.3's, LR4/L33 Flat tops) my question is are there any PTV clearance issues if the prc's are milled down to the 58 cc's? My original plan is to swap in the Wiseco 5.3 pistons with the valve reliefs cut in, but if that is not necessary, then I would rather take the cheaper route if i didn't have to drop 600 dollars on a set of forged pistons on a head & cam only motor.
Disclaimer: yes i understand buying a bigger bore engine would make more power in the end- but i got this engine for free basically.
Budget build FTW
Old 03-25-2011, 01:01 PM
5.3LJimmy's Avatar
Budget build FTW
You will have enough room to run a 224/224ish cam which is plenty for a 5.3. I just built this exact setup using stock heads milled 0.030" with an .040 gasket and 224/224-112+4 cam. PTV was .12x intake/.14x exhaust. The larger valves on the ported heads will reduce PTV some but you should be fine.
It's always a good idea to check your actual PTV as variances in deck height and valve height on the seat can be different. I only quoted my measurements to give you an idea of what to expect.
Quick Reply: Stage 2.5 5.3 heads on a 5.3?
