rocker selection
look on your cam specs for your lift. for instance, the torquer v2 is .598/.595. That is on a stock 1.7:1 rocker arm ratio. If you wanted to jump to a 1.8:1 ratio, your lift would change by the difference. To calculate it take the lift/1.7*1.8
.595/1.7=.35
.35*1.8 = .630
The MS4 already has such a high lift that I don't think there would be any benefit from a larger rocker ratio.
.595/1.7=.35
.35*1.8 = .630
