What makes popular cams good power makers?
TR220,224,230's TSP 231/237, MTI 244/244, 242/242- these cams are what I see around the most. For example, the TSP 231/237 is one of the newer cams being used but, if I were to have 232/238 or 230/236 with the rest of the specs being the same, it wouldn't be as good as the TSP would it? What all do you need to take into consideration when building a motor and wanting a custom grind cam? How do all the specs in a cam affect the power range you're looking to use? Duration, lobe seperation angles, lift, lobe inclination angles, etc?
The combination being used, the parts, and the intended power range will decide the optimum camshaft. Flow numbers, stroke, rod length, bore, compression all of these factors relate to camshaft. Shelf cams are starting points for customers to use with relative engine combos to obtain proven power. Its the safe route to go. Custom is for the ones that want every ounce of power out of the combination.
Chris
Chris
LS1TECH Sponsor
and keep in mind sometimes custom cams arent the way to go because most of them arent proven and just work well on a computer sim of how they are supposed to work....Cstraub is absolutly correct though every part of the cam specs affect how and where it will make power. And there are hundreds of factors that can come into play when choosing the correct cam even if it is an off the shelf one.
lata
Bill
lata
Bill
A true custom cam shouldn't be proven for anyone else except that combination that it was designed for. And your right, my cams never do make what the computer says, for some reason its like a Stuska, stingy with power ratings. Out of 100's of camshafts, I have had 2 not perform correctly. . .but I did those without airflow figures and based it on averages. I don't do that anymore.
When looking to do a custom camshaft, look for someone who ask a lot of questions pertaining to the combo, heads, airflow, power wanted and such.
Chris
Chris
SN95 Director
Chris
Chris
alot of R&D goes into the off the shelf cams and the popular ones have just proven themselves to work great in a multitude of setups. If i remember right someone already tried what your thinking off, taking the cams specs of another cam and going 2* bigger on duration for a custom cam and lost power.
Silent, The only thing that is clear from your question is that you want to understand how various camshaft parameters relate to engine performance. That is a noble goal but a poor starting point for choosing a custom cam. Since you have not clearly stated your requirements it is not clear why none of the many off-the-shelf cams is suitable.
Respectfully, Gary
Respectfully, Gary
Respectfully, Gary
Respectfully, Gary
I'm trying get everything in order for this next setup to be a step ahead. I'm looking to build a 427 hudraulic roller-4"stroke x 4.125" bore w/ perhaps a 6.125" rod and the pistons will be dished to achieve 12:1 CR. I plan on a dual stage ~125/250 wet shot. I want max effort setup that is somewhat streetable. If there's any other details I'm leaving out let me know, thanks. BTW, drivetrain is in the sig.
“I want max effort setup that is somewhat streetable.”
This statement and the fact that you have an automatic transmission go a long way toward determining your cam choice. I still don’t think you should be considering a custom cam for two reasons: The first reason is that your requirements are not especially unusual. You can benefit from the experience of others who have similar requirements and setups by choosing a proven camshaft. The second reason is that compared to the expense and effort you are investing in your car, installing a different cam at some future point is relatively cheap and easy. You might want to try several different cams before you find your ultimate, possibly custom, cam.
-Gary
-Gary
Very true and is a safe route to go if the car is not in competition, but if you are running competitive classes you can't follow the pack.
Not picking on you and don't mean any flames but their are some people that know their stuff and know how to really make power.
Chris
It has been my experience that the cam is chosen based on what the heads/intake/exhaust are doing.
Analyze your head flow, intake/exhaust CC's and flow numbers, intended rpm range, gear/converter selection, whether or not vacuum is a concern and then pick a grind accordingly.
When my customers give me all the info I require to design a camshaft, the right cam is always the first one I send them. . .its much cheaper this way.
