to change my cam or leave it alone?
have seen people pick up 10 rwhp stepping up to a ms3.are the heads milled?what chamber size?consider PTV .TSP 5.3 heads have their valves sunk into the valve seats to gain clearence.
thanks for the info,
but by info so far, it looks like im going to stay with my cam,
cause
1. im NOT getting different heads,
2. if im only going to gain 10hp then its not worth $400 for the cam , then absolutely not putting it in .
cause
I would keep the cam you have. A MS4 or similar cam will make more power but at high rpms. Personally I like a smaller cam that makes more power through the curve as apposed to a big cam that makes all its power uptop. You will also want to take into consideration piston to valve clearance on the bigger cams.
I run a vrx4 and I feel like it makes good power throughout the entire pull and I dont have to turn it as hard.
