Blown head gasket.. Does this look ok
Old 01-23-2011, 10:31 AM
speedracer2536's Avatar
Default Blown head gasket.. Does this look ok
So i blew a headgasket.. My question is this.. This looks just like burnt coolant and it seems to rub off with some elbow grease.. Does it look ok? or is the wall trashed?
Old 01-23-2011, 11:41 PM
AAK z28's Avatar
It looks fine just clean it up and make sure the cylinder wall isn't scored up
Old 01-23-2011, 11:49 PM
Mart00SS's Avatar
ummm the "rusty" colored stuff doesnt look bad it will probably clean off, but how about that nice mark in the top of the piston from the valve, thats not good....
Old 01-24-2011, 12:56 AM
trans_am7935's Avatar
just wipe it off then when before you start the engine squirt a little bit of oil in each cylinder to burn them out clean, then change pull the spark plugs and clean them. im with Mart on this one, what is up with that nick in the piston, does not look like a happy motor. stock cam or not?
Old 01-24-2011, 01:00 AM
Whiteaw57's Avatar
oh boy this sounds interesting.....subscribed
Old 01-24-2011, 01:33 AM
01ssreda4's Avatar
The piston is winking
Old 01-24-2011, 02:15 AM
masterz28's Avatar
Walls are good, I heard a little kiss from the valve to the piston is not bad, but THAT looks like a concern.
Old 01-24-2011, 08:49 AM
LOL that happened 20k miles ago.. Heads have since been repaired.. when i spun the motor over to check the cam the crap came right off..
