Head/Engine specs
Old 01-25-2011, 05:26 PM
southernculture's Avatar
Default Head/Engine specs
I am curious about LQ4, LS1, LS3.....etc heads. I am looking for info such as flow characteristics what they cam of off(vehicle and displacement) I have been trying to figure this out, but am not sure really how to search. I am really looking to find a better head than my stock ls1 heads. I would like to buy a set of heads to take to the machine shop to have a valve job done and have my comp 918's and titanium pieces put in instead of just using my stockers. I have seen a bunch of numbers like 281 heads. I am familiar with heads from gen I sbc. When I hear casting numbers for ls series motors I have no clue. Thanks for the help in advance, I am sure there are people in here that can answer this in a few minutes!
Old 01-25-2011, 06:08 PM
Darkman's Avatar
You can search for the castings numbers. For example, here is some discussion on the 243s/799s which are a popular upgrade over 241s and other castings.
https://ls1tech.com/forums/generatio...-vs-243-a.html
Old 01-25-2011, 07:07 PM
garygnu's Avatar
try smokemup.com or try wikipedi .liked stated above look for those casting numbers he listed .a 317 head has the same ports but a bigger chamber.
Old 01-25-2011, 07:18 PM
That is what I was meaning. I have 241's stock in a ls1?
241-ls1
799-?
243-?
And really have no idea what others there are. I have searched and have been scraping the surface but really cant understand what goes with what. I can look the specs up but am not even sure what to look up or search for.
Old 01-25-2011, 07:28 PM
WS6sleeper's Avatar
799 (98-99 LS1 model heads)
243 (LS2/LS6 heads)
Correct me if I'm wrong!
Old 01-25-2011, 09:18 PM
Darkman's Avatar
LS1 heads include 806s, 853s, or 241s depending on the year.
http://outintheshop.com/faq/casting/heads.html
Old 01-26-2011, 04:35 AM
PREDATOR-Z's Avatar
http://chevythunder.com/LS1%20compon...20ID%20Numbers
Old 01-26-2011, 06:07 AM
OK the thunder racing had everything I was looking for! Thank you very much!
Old 01-26-2011, 06:30 AM
garygnu's Avatar
if you are looking to buy some 243s or 799 heads check the corvette and GTO ls forums also.have Pred-Z spec you a cam .
Quick Reply: Head/Engine specs
