400 hp LS1 build, Stock head bolts?
Old 02-10-2011, 10:48 AM
LS1Sacrelig's Avatar
Default 400 hp LS1 build, Stock head bolts?
Im putting together an LS1 planning to make around 400 to the ground and was wondering if using new GM head bolts is a waste of time...I dont want to stud it, but I am definately considering ARP head bolts. Just curious as to whether or not stock head bolts are worth using, or should I just go ahead and purchase the ARPs.
Thanks
Old 02-10-2011, 10:51 AM
brians91formula's Avatar
402rwhp here and factory head bolts and factory un touched heads. Maybe do ARP for piece of mind ?
Old 02-10-2011, 11:04 AM
Cool...Whats your set up to make 402whp?
Old 02-10-2011, 12:15 PM
pwrtrip75's Avatar
stock bolts would be still an overkill for that. I've re-used stock bolts on a couple different turbo apps. each over 600whp. and never had a prob.
Old 02-10-2011, 12:36 PM
RARON455's Avatar
My first engine I built before my stroker I have now put out 463 RWHP and 428 ft. lbs and ion top of that I sprayed a 150 shot,Stock head bolts never any problem. He stock head bolts are chromeoly steel and up to the job. drop em in and go.
Old 02-10-2011, 01:17 PM
402/378 on a Mustang dyno
Full exhaust with no cats and cut out
UD pulley
Lid
227 /233 custom grind cam
stock ls1 intake
Old 02-10-2011, 01:26 PM
slt200mph's Avatar
Back about 7 years ago I went with a Lid, LT headers, and a TSP Torquer cam and made 414/389 on stock heads.The stock head bolts are fine but if you are going to do heads in the future get the ARPs so you can reuse them.
Old 02-10-2011, 04:39 PM
LS Desert Ranger's Avatar
When everybody is sayin stock head bolts, do you guys mean the orignal stock head bolts or NEW stock head bolts?
Old 02-10-2011, 07:28 PM
pwrtrip75's Avatar
I have re-used the original ones. Lots of people have. Its not the politically correct thing to do though.
Old 02-10-2011, 10:24 PM
whats wrong with reusing the original stock head bolts?
Old 02-10-2011, 10:27 PM
SuperSport01's Avatar
They are torque to yeild. Meaning they are stretched to the max and are technically unusable afterwards.
Old 02-11-2011, 12:46 PM
Sweet! Thanks guys, experience is the best reference...My heads are stock just worked a little, and I dont plan on doing any big mods for a while.. Its going in a 90 240sx, so 400whp should be plenty and gonna take some time to get used to for me... I got the worked heads, MS3, bbk 80mm TB, stock C5 non EGR intake, and custom 1 7/8 long tubes for the application...Oh yea and a Melling high flow/volume oil pump (had oil pump issues with my last project and will never overlook that again). Looks like ill be calling the Chevy dealership this week...
Old 02-11-2011, 06:27 PM
garygnu's Avatar
TSP sells stock head bolts and mite be cheaper then the dealership.they have gaskets to.
Old 02-11-2011, 06:40 PM
jim ravencraft's Avatar
Hi,
i would agree on using new bolts due to stretching when torqued. I would like to see you spend that little extra $$$$$$$$ for new arp bolts and have peace of mind. Anything mechanical can fail and will fail at some point. Exercising due caution and proper build procedures is a must.never sacrifice quality for a few $$$$$$$. Best of luck with your project and have a blessed weekend..captain jim
Quick Reply: 400 hp LS1 build, Stock head bolts?
