408 stroker build... H/C/CR questions
found an LQ4 and put it into a blazer and spun main bearings, rod bearings, crank is junk, rods are out of round... So now i'm going for the stroker. Plan is 408 stroker with a TSPd rotating assy.
This is for a daily driver with multiple trips to the track throughout the summer with plans on spray. i will have A/C and would like to keep it fairly sleeperish.
1. which cam would best suit my needs (i like the one i have now, but i know there is a lot of improvement to be had)
2. will the 317 heads hold me back or should i spring for a new set?
3. what compression ratio should i go for. i would like to stick with low to mid grade pump fuel.
Parts on hand:
LQ4 stroked to 408 (line bored, all bearings replaced, decked)
LS6 intake with fuel rails and TB
317 heads
comp 918 springs
LS1 XR265HR-15 (212/218 265/271)
Sanderson headers
2.5" dual exhaust with DMH cutouts and a 30" magnaflow
Parts i will be ordering:
TSP 408 rotating assembly
TSP ported LS6 oil pump
LS7 lifters
as soon as i figure out what what compression ration i will need then i can pick a wiseco piston...
I would appreciate all advise. I called TSP today, but didn't really walk away learning anything... and thats why i am here.
Parts on hand:
317 heads
comp 918 springs
Sanderson headers
LS7 lifters
you mite need bigger injectors.the 317 heads will work,mite not need any milling .look at some comp LSr cams,54-455-11 more torque then the one you have..maybe get consider some pac 1218 or 1518 springs.and also consider some compcam trunnion bearings .
Never thought about the trunnion bearings.. any one have good luck with these?
**UPDATE**
Here’s what I got going in a 4 door blazer with a Silverado 4L60E/Trans Go HD2 kit and stock rear end with 3.73 gearing. Going with the sleeper look with stock body and lowered with ZQ8 wheels. Need a recommendation for a cam that idles like stock with A/C and possiblity of spray, but puts out power while DDing.
Motor is as follows
LQ9 Iron Block
Diamond Pistons -4 Valve relief
Total Seal Rings
Eagle 4.00" Stroker Crankshaft
Eagle H-Beam Connecting Rods w/ARP rod bolts
Cam bearings installed
Clevite " H " Race Rods & Main bearings installed.
Fully balanced / Line honed block.
GM galley plugs / coolant plugs / oil plugs installed
Plasma top rings
Ported 243 heads with patriot dual springs good to .650 lift (flow almost 300cfm at .600 lift)
LS6 intake, TB, injectors
TF Chromemoly 7.4” push rods
LS7 lifters (still deciding)
TSP LS6 high flow oil pump
Timing chain (would like recommendation)
Cam (would like recommendation)
Reccomendations would be greatly appriciated... trying to figure out comression ratios, but having a hard time.
What do you guys think?
Motor is as follows
LQ9 Iron Block
Total Seal Rings
Plasma top rings
As far as cam goes your cam is REALLY small for a 408. If you want a small cam for a 408 go with something in the 23x's range.
The heads will work but you are going to leave alot of power out there. There are lots of budget friendly heads out there that will give you much better power gains. TSP has lots of budget friendly heads.
I dont know much on how octane effects compression. Octane of the gas is also going to effect how much timing you can put into the tune. If you are ok with mid grade then you are only looking at maybe $3.00 more to fill up 15 gallon tank with premium vs mid grade. Just go with premium and save you and your tuner lots of head aches.
The ls6 is a good intake. If you are on a budget stick with it, if not upgrade to a fast of some sort.
Parts on hand:
317 heads
comp 918 springs
Sanderson headers
LS7 lifters
Parts on hand:
317 heads
comp 918 springs
Sanderson headers
LS7 lifters
Thanks for taking the time to give me your .02 silver. Well, I got some updates. Plans have changed... Motor and bottom end will remain the same. top end has changed. Give me your thoughts. After thinking about it, I’ll probably either do midgrade or premium. What’s another 3 dollars for some good gas?
LQ9 Iron Block
Total Seal Rings
Plasma top rings
Stock L92 Heads with lightweight LS3 intake valves
GM Performance head gaskets compressed to .051
Stock LS3 intake
NW 90mm DBC TB
LS7 lifters
Stock LS6 oil pump
LS2 timing chain
COMP Cams spring kit 26926TS-KIT
25% underdrive pulley – powerbond
227/235 .639 .621 114LSA+2 LSK/LSL lobes
Trans Specialty TQ 2800-3200
Any suggestions are appreciated. This should put me right in the range of 10.9-11.2 CR. Depending on what CR calculator you use… any HP guesses?
LQ9 Iron Block
Total Seal Rings
Plasma top rings
Stock LS3 intake
NW 90mm DBC TB
LS7 lifters
Stock LS6 oil pump
LS2 timing chain
LQ9 Iron Block
Total Seal Rings
Plasma top rings
Stock LS3 intake
NW 90mm DBC TB
LS7 lifters
Stock LS6 oil pump
LS2 timing chain
LQ9 Iron Block
Total Seal Rings
Plasma top rings
Stock LS3 intake
NW 90mm DBC TB
LS7 lifters
Stock LS6 oil pump
LS2 timing chain
my setup will consist of a custom cam callies crank and rods diamond pistons stock thickness gaskets with 317s that are ported and milled to 68cc should put me around 11.3.-11.5 CR
I would do the l92 setup if you have the $ for it no doubt! im just trying to figure out why the small cam?
Heads and intake are already sitting on the table... I picked the cam based on the fact that I want nice down low torque and to be able to daily drive and not worry about traffic with the A/C on. As far as I know I shouldn't have a problem with this setup. What’s a medium sized cam to you for a 408?
I think choosing a cam is my hardest decision... as is with most other people... i also think that there is no need for me to go that big and still pull good numbers out of this stroker. how does this cam perform for you and what do you have with it?
Just a thought..
Right on man, you right... I'm going to have to get a hold of someone and get one speced so that i get the most out of this motor. the las thing i want to do is put one in and regret no going bigger.. or smaller... or whatever. thanks for your help
That looks much better. The ls3 topend will help you make much more power. I cant estimate the power you will make but it will be much better with a ls3 setup vs the 317 heads and ls6 intake. Keep in mind your an auto and it is not going to make high dyno numbers.
I think your cam choice is good for the things you are after as far as driveability but I am not a cam expert and the l92/ls3 heads take a little different cam pattern than cathedral port ls1/2/6 heads. Get with the shop you are buying your cam from or even call someone like comp cams to help with your exact cam best for your setup.
LQ9 Iron Block
Total Seal Rings
Plasma top rings
Stock LS3 intake
NW 90mm DBC TB
LS7 lifters
Stock LS6 oil pump
LS2 timing chain
LQ9 Iron Block
Total Seal Rings
Plasma top rings
Stock LS3 intake
NW 90mm DBC TB
LS7 lifters
Stock LS6 oil pump
LS2 timing chain
