Head gasket removal....
I am almost done with the tear down on this moster. I am swapping the heads to 243's and I need to know how to get the old gasket material off the block. I do not have the motor pulled so everything is exposed!!!
How can I get this OEM gasket off with out getting it in the coolant vents or piston heads.
Anyone know of a process that will work?
Do I have to get it back to shiny aluminum?
You're gonna get chunks in the coolant, but try to avoid it. And getting it in the pistons is fine, just vacuum everything out after. I avoid the blow gun because it could splash coolant if the air hits the coolant passages.
And some of those "cookie" wheels can hut into the aluminum. The blue should be fine, just don't use the green or brown ones.
plastic ice scrapper worked well for me , just be patient and take your time, be sure to suck out any bits you get into the pistons , stuffing a rag so nothing gets into the lifters is a good idea too.
be sure to clean all the coolant out of the bolt holes too ! a good way for this is to roll up some paper towels into fine points and just take the time to do each hole soaking up the coolant if you havent allready done so.
I am going to take an old head bolt and cut a groove in with a dremel so I can clean the threads too. I hear that will crack the block also when you torq to spec.
Thanks for the assistance.
