Who sells injectors the cheapest??
Old 02-15-2011, 09:37 PM
bmf5150's Avatar
Default Who sells injectors the cheapest??
Looking for some 36lbs injectors!!
Old 02-15-2011, 09:43 PM
pwrtrip75's Avatar
Its been a couple years since I bought mine but this place had them the cheapest then.
http://www.neweraperformanceparts.com/
I think i got them off their ebay page, but they are a sponsor on here.
Old 02-15-2011, 10:44 PM
peterlawl84's Avatar
I have a set of FIC 42 lb injectors that were just serviced and flow tested to ensure everything was ok for sale. PM me if interested.
Old 02-15-2011, 10:59 PM
01ssreda4's Avatar
FIC is the way to go.
Old 02-15-2011, 11:11 PM
98 StealthZ's Avatar
contact JeremyF from Fasterproms, they are a site sponsor and have a kick *** deal on flow tested injectors..
Old 02-16-2011, 11:26 PM
slow00gt's Avatar
cant beat FIC. If you have a stock set of ls1 injectors he can flow and match them up 60#'s for under 200$ i think
Old 02-17-2011, 08:39 AM
thunderstruck507's Avatar
Don't a lot of people use Cobra injectors?
Think you can get those for $100-150
Old 02-17-2011, 11:10 AM
Cold06's Avatar
Whats the turn around on doing this? week, couple days, or a month?
Old 02-17-2011, 11:28 AM
studderin's Avatar
Got mine from New Era, had them flowed too. Put the strongest in #7
Old 02-17-2011, 11:42 AM
KCS
Moderator
KCS's Avatar
A day or two IIRC.
Old 02-17-2011, 01:17 PM
PREDATOR-Z's Avatar
Ford SVO 30 lbs are actualy 36lbs at our fuel pressure (4 BAR).
Old 02-17-2011, 07:10 PM
garygnu's Avatar
thats a good idea putting the best injector in #7.FIC has some good prices.
Old 02-17-2011, 10:29 PM
01ssreda4's Avatar
There is no turn around. You order them, they ship them, then you send your stockers in after you receive them. I'm running a set of 42lbers.
Old 02-18-2011, 03:27 AM
LS-240's Avatar
when you say "put the strongest in #7", do you mean put the injector that flows the most in #7? why is this?
Old 02-18-2011, 05:50 AM
Cold06's Avatar
Because #7 is notorious for running lean and this will hopefully shop it before it happens!
Old 02-18-2011, 06:40 AM
nodrok's Avatar
Went FIC here
Old 02-18-2011, 07:36 AM
01ssreda4's Avatar
Guys, injectors are supposed to all flow the same
Old 02-18-2011, 10:09 AM
FastKat's Avatar
I second this - FIC is awesome. Their prices are great and service is top notch.
After receiving back my flowmatched injectors, I had an installation question and called them after business hours on a Friday. Not only did they pick up, but the guy gave me his cell number to call him if I had any questions after he left the shop. You don't see that kind of service very often!
Old 02-18-2011, 10:12 AM
FastKat's Avatar
Yes, but if you have one or two injectors that run a little rich (push out slightly more fuel than the others) you can use it to your advantage. In LS1 engines, due to the manifold design, the two rear cylinders (#8 and especially #7) get a little more air pushed into them than the others. If you have a couple injectors that spray out a little more fuel, it's a good idea to put them on those two cylinders to help prevent a lean condition in those cylinders, which is caused my too much air and not enough fuel.
Old 02-18-2011, 10:28 AM
darooke's Avatar
Is fic an abbreviation? and are they a site sponser?
Quick Reply: Who sells injectors the cheapest??
