lookin into a 6.0 block
hey im lookin into buyin a 6.0 block wat adaptions do i need in order for it to fit and start wit no problem.....im goin to use a v3 cam wit maybe the stock heads dependin on the budget built...any feed back wit be hella helpful.
Quick test because 06/07 were transition years
Smooth flat timing cover like your LS1 had is a direct swap. Just drill/tap the alt bracket boss
Cam sensor up front or VVT thing requires the tweaks a LS2 would require because of the conversion from GEN III to GEN IV. Also check the crank reluctor. 24x works fine with your stock PCM, 58x requires a conversion box or custom harness with the newer PCM
i called texas speed and they were tellin me evrythin should work fine jus got to by a little kit to adapt som harnesses my other question is wat is the diffrence of the 24x and the 58 and how do i tell the diffrence bettween the two wit the block that im try to look for??
IMO, spend your $$ on some English classes. Much more beneficial to any live American
I didn't even try syntax and punctuation.
: Txt speak doesn't cut it, amazing how many do it these days when writing.
i called texas speed and they were telling me everything should work fine just got to buy a little kit to adapt some harnesses my other question is what is the ........
Imo, spend your $$ on some english classes. Much more beneficial to any live american
i didn't even try syntax and punctuation.
