Texas Speed MS3
You may get some other inputs but I am putting ls6 heads on my ls1 and I wanted the ms3 bad! But I was going to use. 650 lift beehive springs and when I called Texas speed they told me they did not recommend that, that the ms3 required dual valve springs regardless of the .6xx/.6xx lift that the cam has. The stock ls6 spring are only rated to .550 or so, so I would think twice about using that cam without changing springs. Shame too I really wanted that cam.
That cam should clear just fine. Be sure to go with a good spring and chromoly pushrods. Also, be sure to get your basic bolt on mods covered before the cam goes in. It needs those mods to make the power it is supposed to. Let me know if you have any questions and we'll get you fixed up!
Jon
Jon
I have the MS3 cam in my 98 Z28 M6..i bought the cam package that came with hardened pushrods and double valve springs...The supporting mods definately help..I bought a ported oil pump, double roller timing chain and i went ahead with a bigger intake to help her flow a lil better. The cam is a beast when u get it tuned right..ive had nothing but impressive results and times with my cam.
That IS a big cam....but the MS3 is a bad mother none the less. I wish I could run it but I dont want that big of a stall....yet. Till shes paid off anyway lol.
I have a ms3 cam in my 99 ss cam only it cleared fine with stock ls1 heads. i have 243 heads getting ported right now. but just cam only full exhaust 6spd stock ls1 heads i put down 385hp and 376 tq it pulls hard.
lifters
Jon
Jon
Captain Double Post
^ you don't have to change the lifters,I didn't for over a year and they were fine,but if you pull the heads I would for sure do them,also I would think about gears if you have not done them yet. My ms4 was a freaking dog down low on stock gears,4.10s made the cam,and in the new rear I will run a 4.30,ms3 is a proven cam,if you have all the bolts ons,gears etc , throw a 150 shot on there and you will never get the smile off your face lol,
(yeah, I know, it's probably been asked 1000 times!)
