Lqs6293 = 500hp?
Old 03-15-2011, 12:27 PM
Old School Heavy
speedtigger's Avatar
Default Lqs6293 = 500hp?
I decided to put some CNC ported LS6 heads on my LQ9. So, what does the motor become? Most 6 liters with 243 heads are LS2. But, mine has an iron block. So it is an LQ-2? or how about an LS-9? Or, is it a LQS-69? Since the heads are ported, they flow like LS3 heads. The only logical thing to do is to pay homage to all of them. How about LQS-9623?
On a serious note, the cam is 222/224 .566/.568 on 112. The compression is 10.88:1. The car is carbureted with a 750 Pro Systems carb. I am thinking it will make 500Hp at the crank. The car is 3370 and 3550 with me in it. 3.90 gears and a 3000 Circle D. Anyone have any timeslip predictions?
Old 03-15-2011, 12:53 PM
-Q-
-Q-'s Avatar
I vote for LQ6. And I think I may steal that for my build as well...
Good luck with the build.
530Racer's Avatar
12.30 if you can hook it up
Old 03-15-2011, 01:04 PM
Old School Heavy
That is some serious camshaft you have in that new build. Looks like you could be headed for the 10 second club.
Old 03-15-2011, 01:34 PM
-Q-
-Q-'s Avatar
I'll have to sink some serious funds into a rear end and suspension mods to get there...but that's the goal. Cam is about the size of an MS3, but the extra cubes of the LQ4 help eat it up a little. I'm optimistic about the combo...should be fun.
Old 03-15-2011, 11:28 PM
A.R. Shale Targa's Avatar
Finally got that oil-pan you were waiting for huh speed ?????????
Recently seen an LS3(376cid) crate dyno @ 483 stock w/ dyno exhaust
carb and no acessories. Then G.M. cnc heads went 492 hp and lastly
a comp 224/230 stick @ 560 ponies. Even uncorrected w/belt driven crap
thats still 520ish. So w/ 12 less cubes your expectations are realistic
and I'm sayin with good drag radials or slicks you should expect at least
11.70-11.85 @ 115mph
Old 03-16-2011, 07:54 AM
Old School Heavy
That would be a strong number. Might have a fun little street thumper.
Old 03-16-2011, 01:33 PM
1lejohn's Avatar
Our old 383 with ported 243's,MS3 ,4.11's and a LS6 intake made 440-450RWHP. You should be close to it. What intake?
Old 03-18-2011, 09:11 AM
Old School Heavy
I really don't have much experience with RWHP. The only car that I ever chassis dyno'd was my 2004 Cobra. It was pulley'd, tuned with a magnaflow cat back. It had 430 RWHP. That car was an animal.
I don't see this car being nearly as strong as your 383. You had more cubes and more cam. Whatever it ends up producing will be measured at the track. I don't plan on going to the chassis dyno.
The engine has an Edelbrock Performer RPM and a Pro Systems Holley DP. I think they said it flows a little over 780cfm.
Old 03-18-2011, 01:34 PM
01ssreda4's Avatar
You need more cam and converter to go with the heads
Seriously, it sounds like a great street combo. Should run good.
