spun bearing or thrown clutch spring (or clutch related)?
I have had my spec 3+ clutch slipping for sometime and one day my car just started running bad as i went down the road. I drove it home easily and its making a spun bearing noise.
-my oil is is a quart or so low and is black because i have been low on cash and couldnt afford an oil change at the time. I also added a quart or maybe two of marvel mystery fluid to bring the oil level up because it was cheaper that $7 quart of full syn.
-i can feel the tapping in the clutch pedal
- i found a few silver specs on the dip stick.
- i pulled all the wires one by one except #7 and the noise didn't go away.
-i still have normal oil pressure like i always have.
-it will tap tap tap and then stop for a sec.
