oil pressure steady at 20
Old 02-21-2004, 06:30 PM
ls1perfcar?'s Avatar
Default oil pressure steady at 20
Ive put the oil pump together like 5 times with a new o-ring to and it keeps on staying steady at 20 lbs of presssure. Its a new tsp ported oil pump. All we have hooked up is the throttle body and crank pulley and we fire it up and it stays at 20 and thats it. Is it ok to run it at 20 or should we let it run for a while and is there anyway to make the oil pressure go up??
Old 02-21-2004, 06:45 PM
98SS Blackattack's Avatar
I wouldnt run it past 2000rpm if it only pulls 20. Rule of thumb is 10lbs per 1000rpm
Old 02-21-2004, 06:50 PM
Formerly 4mulaJoe
LS1x2's Avatar
does it go up with rpm? What was it with the old pump?
Old 02-21-2004, 06:51 PM
It idles at 1000 rpms and its pushin 20 psi of pressure and at 2000 rpms its at about 36 psi or so.....Can I go ahead and put everything back together and drive it without worrying about anything?
Old 02-21-2004, 06:59 PM
That sounds better then. Take it alittle higher and see if it goes to 45+. You are in a safe range so far.
Old 02-21-2004, 07:22 PM
ok I revved it up to about 3k or so and it got almost 50 so am i going to need to break in the oil pump or somethin? im usin penzoil 5w30 and right after i break in my tsp cam im going to change to mobil 1.
Old 02-21-2004, 09:17 PM
99 Black Bird T/A's Avatar
Received 1,435 Likes on 995 Posts
I'd call up TSP and ask them what pressure I should expect from their ported oil pump. They should be able to steer you in the right direction.
Old 02-21-2004, 09:25 PM
ss rally red's Avatar
Agreed also try a 10W30 and see if you get a increase in pressure. Believe it or not according to Alldata, GM specifies 18 lbs of pressure at 2000 rpm hot and 24 lbs of pressure hot as minimum
Old 02-22-2004, 07:46 AM
HS-Y2kFormula's Avatar
My brother has been running 18 to 20 psig of pressure with an ARE ported oil pump for three or four years now. It had been at that pressure since he bought it with 9000 miles. Back then, he was worried and a little ticked that the pressure was the same at hot idle. (At cold idle, it did go up significantly!)
Last year, he had an H/C/I package installed at around 40K miles, and everything is still fine. He has driven it every day and is not easy on the car!
I think you are fine with that pressure.
