WTF thermostat
WTF thermostat
I go to autozone today and pick up a replacement t-stat for my 98' camaro (with an 00' vette motor)
Here is the replacement, it looks like a normal tstat, one unit:
I pull out the housing and the spring pops out of the housing. It looks like the tstat is built in to the housing and there is no way i can install what i bought.
What's going on here? Help would be appreciated!
The knowlege base here is getting pretty pathetic. The t-stat they sold you is for a 04 and newer water pump. Separate housing and t-stat. Even if you got the housing for it it will not work in 03 and older water pumps. 97-03 water pumps used the housing and t-stat, all one piece design. Likewise it will not work in a 04 and newer waterpump. The water pumps will interchange between any year gen 3 engine so it is best to know the year water pump you are purchasing a t-stat for. For the older style, Oreillys has them under a Murray brand 160* Pt# 37960, 180* Pt# 37980 and 187* Pt# 37987.
Okay problem, I went back to the parts store. 98-02 LS1 motors all have the same part number, even the 05 GTO and 05 vettes (6 liter) had the same part number. This was pepboys.
what do i need to buy? or was pepboys just wrong?
Okay, problem solved. I went to autozone and they got me the correct part. It's a t-stat built in to a housing and it was $21 dollars. Pepboys parts catalog is WRONG, to anyone going to pepboys for the old style t-stat. Don't go there.
Here is the correct part:
