Broke another Comp 918 spring
Fortunately I didn't do any damage to my bottom end and only slight damage to one valve. The machine shop doing the valve job/head repair is also putting in nitrided double coil springs with titanium guides and locks. These springs will be good to 660 lift.
This shop also builds all the LSx engines for Mosler, so I am in really good hands. Hope to have all this done by next friday.
New news; I decided that it was a good time to go with a forged bottom end. So they (machine shop) will line bore (40 over), use Mahl pistons, Clevite bearings and Eagle rotating assembly (11.4 compression ratio) with the internals balanced and blue printed. New GMPP water pump and Harmonic balancer will added when reassembly begins.
pac did have some problems recently with the beehives but not with ls applications. i think it was with the mopar late model hemi's. i have pac 1518's and have had zero problems.
pac 1518's are the only beehive i've seen lately that i would trust. but you have to know how to set them up. and i wouldn't personally run anything over .610 with them. they are rated at .650 but rumor is they have problems with anything over .637 lift. and i would never trust 918's with any kind of agressive lobed cam.
bout to purchase a set for my new set up. EPS 230/234, ls7 lifters, ls6 valves, comp trunions, 1518's, and ti retainers with milled, ported, and vj'd 799's. hoping for a good mid range and power till 6800.
also going with a diamond stg 2 clutch/fw combo. hoping it's better than the spec pos
and yeah when ever i get started i'll paste a link in my sig. will also be doing suspension and 17" street lites
