? about my Cam.
? about my Cam.
I recently bought a cam locally and was told it was a crane cam XER (torquer 2). Was through a friend of a friend and thought it could be trusted. Well, its not. After giving my friend the money to get it and it sitting at his house (without him looking also), I finally was able to look it.
Crower cam
240/246 .610 lift 114 lobe.
The question is, can I use .600 valve springs and still be safe?
The heads are stock and valve train will be replaced.
Crower cam
Last edited by epglxspooky; 05-01-2011 at 11:14 PM. Reason: Not leaving it totally stock heads on it.
Crower cam
Crower cam
This isnt for a stock cube daily driver is it? that's an aeg big cam for stock cubes, but more suited for a stroker.
I would never run s cam with higher lift than what the springs are rated.
It will be for a DD, so I might just sell it and get the cam I want for my car.
I ran a 238/242 .595/.595 112lsa in my 346 and it was very peaky and bitchy
Sell it and get a different cam more appropriate for your set up... Like the Torquer v2 you wanted in the first place. Then go punch the friend and the Friends friend in the junk!!
www.crower.com
Go to cam card finder and put this in:
e-56408
Tells you pretty much what is needed to know about the cam. Thanks again.
Lift is not the sole determining factor as to whether or not the spring will work. Some springs will go signifigantly above their max lift rating if tested, but that is not the main issue here. A cam with those specs will most likely not even fit in a stock engine without flycutting... Also, definitely not a cam for a daily driver, that thing would want to peak above 7Kin a stock cube motor...
Shane
Shane
