Cam for ss3600 stall?
Just did the ss3600 and now I want more power. A cam seems like the thing to do. The car is a 95% street car but not a commuter. I drive the car almost every day spring - fall but its only to have fun
I dont think the car goes on a sniffer test so thats probably not a problem. I would like to get a cam that will give kick *** torque everywhere What do you guys think?
1 Post
Just bought a EPS cam kit 226/234 113 lsa .598 .601 TEA dual springs Trick flow hardened 7.425 pushrods From TeEnAgE pHeNoM in the classifieds section for a decent price. Cant wait to get it and install it.
You won't have to rev it high, it will make for a great dd, still get decent gas mileage. It isn't much smaller than the street sweeper mentioned above. It should give you about a 40-50hp increase. The 112lsa on the cam will bring torque in sooner and allow you to not have to rev as high
With a cam like that, would you have to flycut the pistons?
I hope you are kidding. A 224 cam Is not even close to needing to flycut. Hell you don't even have to utter for an ms3 with stock heads, or ms4.
Stick to something high 22x/22x under .600 and 112-113 Lsa. Anything similar to that will keep you happy for a long time.
Personally I would buy sweets that he listed above. If you want a larger cam sell or trade it and get a bit larger one.. that's a good deal for everything there.
Restricted User
Btw thought i wuld add i have a similar stall (3400). And i am getn a similar cam probly from tsp. Im going with either the 224r or the 228r on 111 or112 lsa. Good thing with this mid 220 cams is u can keep ur low end torqe and mide range power and u dont have to rev them to the moon
Get something low-mid 230s or you will just regret not going bigger.
I daily drive my car with the 230/224, the chevelle is likely a couple hundred pounds heavier and it still has torque out the nose in low/mid rpms.
If I were doing it over something 230-232/236-238 with around .600-.620 lift would be what I was looking for, get some expert advice from Pat G, Predator, and Geoff to fine tune the specs.
Hows your mpg with that cam? What kinda power did you pick up with it? Whats the power band like? Thanks!
