What camshaft is the best to make around 390-410 rwhp?
You gave no info on your car or what you want it to do. A good all around cam that drives well is a 228/232. Makes good power and will drive great after a tune. Should be no issues with stock heads but should up grade the springs on any new cam swap. If you have any supporting mods this will help get you in your goal area.
To make this power in a useable manner for the street/strip if it has a lopey idle im ok with that but since i have only played with the gen 1 small block i figured i would ask a opinion from guys who have been there and done that i thank all of you who gave input because it will def help me in the long run. Also i might be able to snag truck 243 heads whats the difference between those and the ls6 243?
Comp cams XER273HR (224/230 581/588). LS6 intake, stock 241 heads, LT, ORY, Magnaflow catback. 403 RWHP/ 390RWTQ. Great street manners. The lope is noticeable but the idle is overall smooth. It depends what you are looking for.
