Cam bearing question, please help.
I have an 04 LQ9 that is getting a 02-04 Z06 camshaft. What cam bearings would I use?
I know there is a 1st design and 2nd design based on the inside diameter of the bearings between 03-04. I measured the cams 1 and 5th journals on the came with a caliper and got 2.168".
I ordered a set of bearing from summitracing but canceled when I remembered there were two size bearings.
I did a more reading use the search function and I think the only thing that changed was the bearings outter diameter in relation to the block, not the camshaft journal size.
