Installed my G5X4 Cam - Video Inside
Finally had time to install the G5X4 Cam that I've had for a while, and tossed on an LS6 Intake, Got a few more things to do and then I'll be ready. Still needs a tune and I'm debating on how to run my exhaust, Not sure if I want to do true duals or not, it's already pretty loud even with the cutout closed.
Matt
Edit: here's a link to some other work that I've done http://www.facebook.com/mrbluemagics...97191266966066
http://www.youtube.com/watch?v=rWJxsP9UJCY
Matt
Man ,that thing sounds mean !! I wouldn't run a true dual set-up with that cam . You might want to consider getting muffler to quiet it down a little ,like a magnaflow or a slp dual-dual . As for heads ,Livernois Motorsports,TEA,TSP PRC's , are all good choices 243's or 5.3 heads. With that cam ,I wouldn't go no less than a stage II cnc's from any vendor you may choose.
Thanks... I still haven't decided on TD's or not, but I'm going with the CME setup so I would like True Duals... I was looking at the Magnaflow bullets as well. As far as the heads go I think the 5.3's would cause a PTV clearance issue, but I do have some 863 casting 5.3's on an engine I bought for my Iroc I wanted to use, so I'll do some research on that one. Hopefully someone can chime in on that...
Btw I have a slowmaster muffler on it now that needs to go. in the first startup the cutout was open, in the last two clips it was closed... didn't make any difference it was still loud lol.
Sounds good the way it is, I'd keep what you got for exhaust.
Question about running these big cams without a tune. So was this the first start with the new cam in? I can understand the ECM taking a couple minutes to adjust for the cam, and then it should idle and not sound like it's gonna die. Just a nice steady lope. Am I correct? Or is that jsut something you have to live with every time you cold start until you get a good tune on the car?
Its going to run like that until it gets tuned, they sometimes idle a little better after the first start up once the PCM learns it, but there's only so much learning it'll do. The first startup it wouldn't idle on it's own.
As far as the exhaust I definitely need to change it because it's too loud, even with the cut out closed it's just as loud. I need to keep it quiet to avoid the CHP and a referee ticket.
ounce you get it tuned it will calm it way down and make it idle and drive so much better I would just probably go with just a tsp y pipe just because its so much easer
