ls6 compared to gm hot cam
Old 02-26-2004, 02:52 PM
68birdls1's Avatar
Default ls6 compared to gm hot cam
how is the hot cam compared to the ls6 cam? which will produce more power? i know the hot cam will make lots of low end torque which is what i want , i dont know about the ls6 though?!? everybodies opinion is wanted. thanks
daniel
Old 02-26-2004, 02:57 PM
jrp
SN95 Director
jrp's Avatar
i'd go hot cam over the ls6 cam. the hot cam has more down low and mid range compared to the ls6's top end. both are pretty mild cams.
i'd shoot straight to a 220, 224 grind myself
Old 02-26-2004, 03:02 PM
68birdls1's Avatar
the thing is, i am putting a ls1 in my 68 firebird, but i dont want to put the motor in stock, so i am just looking for something until i can actually build the motor later. for now i am just gonna get a cam, ls6 intake, headers, and maybe a tb or maf, and a 3000 stall. it is mainly going to be a street car, but i will take it out to the track!! so what would you recommend for a person wanting to make about 375 rwhp? thanks
daniel
Old 02-26-2004, 03:05 PM
jrp
SN95 Director
jrp's Avatar
both will get you 375rwhp, i'd go the hot cam though. will give your car that muscle car sound with all the overlap compared to the ls6 cam.
Old 02-26-2004, 03:35 PM
equandt's Avatar
The hot cam will do exactly what you want. Your 68 will have a nice muscle car rumble to it too.
Old 02-26-2004, 03:47 PM
TaTommyWS6's Avatar
Click on my "hotcam exhaust" soundclip on this page:
http://www.tatommy.com/Video%20Clips.htm
Hotcam makes good torque, and sounds great.
Tommy
Old 02-26-2004, 03:48 PM
2xLS1's Avatar
LS6 cam in an auto car is plug and play. You will have to have tuning to run a hot cam with an auto. Just something to consider. Although, putting a LS1 in a 68 is going to require cutting the sub frame and boxing in the cuts, so something like a little tuning might be a minor issue.
Old 02-26-2004, 04:16 PM
Steve98Z's Avatar
Go for the hotcam, I wish I had a soundclip of mine chopping through 3" true duals with idle set at 750 rpm, you would be sold instantly!!!
Old 02-26-2004, 05:02 PM
68birdls1's Avatar
tatommy, the car sounds good, i am wanting to put lt headers on the car, but if i cant then i will go with some shortie's! but it will be three inch true duals. and what kind of numbers are yall running at the track with your hotcam? and what all do yall have done? i just want to see what i might beable to do! thank
daniel
Old 02-27-2004, 08:44 AM
TaTommyWS6's Avatar
I have no track times yet. I don't have the ***** (actually I have no friggin' money) to ruin my stock 10bolt yet. I have some real traction issues with my stock tires and 4.10s, but it is fun as hell for the street. If it's any indicatrion, I can tell you I have raced ZO6s, SC cobras, etc on the street and walked them all. All my mods are listed below. It pulls hard in the midrange which is what I planned for.
When the 12bolt comes, the fun will really begin!
Tommy
Old 02-27-2004, 10:46 AM
68birdls1's Avatar
thats impressive, i just want the car to be a lil more badass than stock, that is why i'm curious about the hotcam. i plan on building the motor better and stronger later on, but for now, just want to beable to drive it lol. ohh i just found out that i wont beable to put lt's on the motor, the power steering is in the way, so do yall know what difference in power is between lt's and shorties. i know i should post this in the other section, but while i have all of yalls attention i thought i would go ahead and ask. and one more quick question, where did you get the car tuned at, did you bring the car to somebody or did you just pull out the ecu? thanks
daniel
Old 02-27-2004, 06:11 PM
TaTommyWS6's Avatar
I tuned the car myself with LS1Edit.
I believe some people say GM's Hotcam is OK with more restrictive exhaust (ie, shorties, stock manifolds), because it has longer exhaust duration. I'm not sure how true that is, I'm sure less restrictive exhaust is always better, but it does seem ideal for you right now.
Tommy
Old 02-27-2004, 08:31 PM
68birdls1's Avatar
was it hard to tune it yourself? do you know of a website where i can see what all the ls1 edit does, and how much it costs? thanks
daniel
Old 02-27-2004, 09:24 PM
Fulton 1's Avatar
daniel
Here are a couple of good sites for LS1Edit purchase and tuning info:
http://www.carputing.com/
http://www.slowcar.net/
Just be aware that there appear to be some alternate solutions just around the corner (check the PCM/Tuning forums).
I'm still running the hotcam with stock heads and LT's in my M6 without much beyond a MAFT in the way of tuning. I realize that with an auto you will need more work, but I think this would be a great "old school"-sounding cam with very little worry until you upgrade to something better. Its a cheap setup, makes pretty good power, and is very reliable.
Old 02-28-2004, 07:16 AM
TaTommyWS6's Avatar
As far as tuning goes, it all depends on how "perfect" you want the tune. If you just want it to idle of, then it is almost trivial using idle. Most people change their VE setting a bit, a little more timing near idle, etc...
But if you want to squeeze the max amount of power out of your setup, you need to use a dyno with a wideband, and fine tune the A/F mixture across the entire RPM range.
There are lots of great documents floating around on this site and others that explain the specifics of what computer setting to modify.
The first topic on this forum is great for idle tuning issues:
http://www.ls1tuning.com/iboard/index.php?showforum=3
Good luck!
Tommy
Old 02-28-2004, 09:10 AM
68birdls1's Avatar
thanks for the websites, i will be sure to read them today. i only have one more question for you... what does VE mean lol. thanks for the replies and i'll post pictures when i get the ls1 in the car. should be within the next 2 or 3 months.
Old 02-28-2004, 02:09 PM
TaTommyWS6's Avatar
VE = Volumetric Efficiency. It is a value used to regulate A/F, etc... Changing the VE values seem to be key to get a good idle (especially during initial startup.)
Tommy
